3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the iTIN
Step 9Optional LED Tester
Optional LED Tester
okay to add an led tester, just get an 8 pin socket from radioshack, like $1.50 for two. Then take a positive(I color coded mine, to make it easier to use, Red=+ and Black=-) wire and strip the ends, and take one end, and wrap around all of the pins on one side of the socket, and solder, then do the same on the other side with your negative(black). now just solder the negative wire onto the negative on the tv jammer(the bottom pad) and the positive to the input on the toggle switch that activates the jammer, then add an excessive amount of hot glue on the bottom for insulation, and let dry, then add more to the bottom, and glue between the back side of the Mintyboost and between the left of the horizontal battery holder and the back end on the toggle switch. Then your Done!!!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:rockandjay
I enjoy making things, the instructables site is my homepage, and every day when I wake up, I search instructables for 3 hours looking for things to spend my day making! I ALSO HAVE A GAIA account Roc...
more »
