The Msr-5 (Mini Sniper Rifle - 5)
9,316
24
161
Published
Introduction: The Msr-5 (Mini Sniper Rifle - 5)
hi
this is my first knex gun. It is a mini sniper rifle to be used in places were space is limited and snipers like the sr-v1 won't fit in. It's design allows it do be carried in a backpack so it can be transported unsuspected. When you are in position, you can build it in under 30 seconds when you have trained.
You can change the stock length in about 15 seconds so you can get in to even tighter places if needed.
It uses a what I call a "zero friction barrel" so that maximum power is maintained over the small design of the gun.
It has also been made with as few parts as possible. so that also people who don't have a lot of knex can make this rifle
It was not made for looks, only for performance.
I haven't found out yet what its maximum range is yet, but I think it would be about 150-200 ft with the right rubberbands. I test fired this gun on my sister at a 15 ft distance, believe me that hurts even with only one (strong) rubberband. I think it is accurate to about 75 ft when your lucky
Step 1: The Trigger and Handle
Basically follow the pictures if you get in trouble let me know.
Step 2: The "frictionless" Barrel
again just follow the steps
Step 3: The Stock
this is the stock, remember these are just the rods that make the perfect length for ME!! if you aren't comfortable with it please change the length of the stock.
Step 4: Putting It Together
this is not too hard
Step 5: The Bipod
this is ridiculously simple
Step 6: The Scope
this is the scope, I realy advice you use it.
Step 7: Loading
needs some skill but realy easy once you know
    • Creative Misuse Contest
    • Clocks Contest
      Clocks Contest
    • Stick It! Contest
      Stick It! Contest
    161 Discussions
    how do you put the rubber band (picture was blurry) please help
    if you whant a better bi-pod just build the one of the commando v3 the bipod is awsome
    lol nice try disney but im pretty sure its 6, 5 doesn't quite fit right :)
    myn weapon dont shoot??
    how?
    that thing that shoot cant go??
    plz help!!
    my english is bad:P
    it looks like you took a really big sniper and made it do exersise for 2 whole years strait!Easy 5*
    This, I have to say, is probably one of my favorite knex 'ibles on the site!
    1. You did a piece count! This one of the top reasons why this instructable is great.
    2. Not overly complicated and no unnecessary pieces used
    3. Didn't require a large amount of pieces
    This is probably the 2nd rifle is was able to build because all the others required too much knex. And to be honest, this shoots alot better than many other guns that require triple the pieces.
