Introduction: The Reaper Crossbow Mods
Picture of The Reaper Crossbow Mods
Here are some mods for the reaper crossbow made by wicky these mods allow you to use ammo without the back grey piece. It also uses a new type of arrowhead that can hold up to 6 rubber band strings. if you are having trouble i will try to help but i may take it apart.
Step 1: Making the Barrel
Picture of Making the Barrel
1. if you do not have the orange pieces you could always use a yellow connector but with this its easier to find the hole
2. this is the main part of the barrel, easy enough
3. now you just add the white connector and the two spaces
4. make these 9 things, if you need help get an adult
5. add them as shown
6. don't forget the yellow rod!
Step 2: Making the Trigger Mechanism
Picture of Making the Trigger Mechanism
1.make these but instead of using blue spacers use red connectors as shown in the next picture
2. this is how to attach the red connector
3. its not rocket science just make it
4. put all of the three parts together as shown
5.attach the trigger mechanism to the main barrel and this step is complete
Step 3: Making the Frame
Picture of Making the Frame
1. make this and remember to leave the gap where a green rod could fit
2. pretty easy apart from the two gaps on each where a green rod could fit
3. add the red rods
4. fix the middle to the first outer part
5. then the second
6. fix it together more strongly with more red rods and a tan, this tan rod is important
7. you should have used this amount of red and tan rods by now
Step 4: Attaching the Barrel to the Frame
Picture of Attaching the Barrel to the Frame
1. sorry for the slightly blurred picture but all you need to do is attach the black "hand" connectors to the tan rod
2. WHAT!!!!!! another slightly blurred picture oh well never mind just clip the yellow rod into the yellow rod shaped gap.
Step 5: Elastic
Picture of Elastic
1. add the elastic
2. same thing just another angle
Step 6: Adding This to Your Trusty Reaper Crossbow
Picture of Adding This to Your Trusty Reaper Crossbow
1. before.....
2. after!!!!
Step 7: The New Ammo
Picture of The New Ammo
1. wow look at it its small and amazing and goes clean through 3 layers of cardboard
apples!!!!! (author)2008-07-22
what kind of connectors are those? ive never seen them before...
dsman195276 (author)apples!!!!!2008-07-22
i have some of them, but i don't know what they are called sorry.
Hiyadudez (author)dsman1952762009-09-06
They are called track splicers, used for tubing.
Hiyadudez (author)apples!!!!!2009-09-06
The are track splicers for orange tubing.
StyleCore (author)apples!!!!!2008-07-22
I have bunch of them. Dont ever use them though
apples!!!!! (author)StyleCore2008-07-22
i figured
plasmaspy (author)2008-08-09
an awesum trigger!! ty ty ty ty without i wouldnt be able to finish my knex flak cannon from unreal tournament 2003-4 :D
sillydude123 (author)2008-07-23
ive just figured out a new type of ammo, will post ASAP
Storm950 (author)2008-07-22
An overall picture would be nice. Those orance pieces are mad! Where did you get them from?
sillydude123 (author)Storm9502008-07-23
i bought a load of knex off ebay (4boxes for £31) and they came with it
About This Instructable
1,310views
2favorites
License:
More by sillydude123:the reaper crossbow modsHow to load killerks sr-v1
Add instructable to:
