Introduction: The Tweiger Counter
The following steps will enable you to build your own tweiger-counter! It searches in current twitter messages sent around the globe for the words like nuclear, calculates a sliding window average and pushes it to the arduino that will click for every incoming tweet like an original Geiger counter and will steer a servo as revmeter showing the current nuclear related posts on twitter. So the next time the twitter-verse is flooded by such tweets due to a new catastrophe you will be warned by an alarm of your tweiger-counter.
what you need:
- arduino
- servo
- little speaker (optional but cool)
- twitter developer account (sorry, but necessary since the recent API update of twitter, they cancelled basic auth)
(-some dependencies for the python script, mainly the tweepy package)
by the way, the code is flexible so can search for whatever words you want, so you can easily turn the tweiger counter into a yolo-meter or check for hurricanes...
what you need:
- arduino
- servo
Step 1: Coding-up
get the code for the python script & the arduino sketch from github:
https://github.com/leftbigtoe/tweiger_counter
in the same folder as the python script create a text file called auth.txt where you OAuth data:
1st line: consumer key
2nd line: consumer secret
3rd line: access token
4th line: acess token secret
it will be read in by the script to connect the tweiger-counter
Step 2: Wiring-up
here is how you wire everything to the arduino. make sure you use the same pins or adapt the code.
Step 3: Suit Up
to make your tweiger counter look nice, just grab some box to put it in and add a nice hand and scale. no exact instructions here, but maybe some insipration:
I just went to the locale tabacco shop, got an empty cigar box (shrinked it down a little since it was a bit oversized) and made a hand I mounted to the servo.
Step 4: Starting-up
quick & easy
connect your arduino, equip it with the sketch.
right click the python script and press edit with idle.
then just press F5 to start the script
your tweiger-counter is now online. you can also watch the console where the tweets will be printed out
commandline & customization
if you want to search for other keywords, you can either change the code or just start the script from the command line with the words as commandline arguments:
user@computer c/tweiger_counter/ $ python tweiger_counter.py keyword1 keyword2 ... maximum
you can pass as many keywords as you want. the normalization argument lets you define for which number of tweets per minute the maximum will be reached. by that you can scale your counter.
os & port issues
the script should automatically detect which operating system you run and try to connect to the arduino on the standard port ("COM4" for windows and "/dev/ttyACM0" for linux). if you can't connect, make sure you are using the right port.
os & port issues
