3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
the ultimate fog machine
Step 3Safety and such
safety and such
ok ok .i know some of you out there are thinking this is a terrible idea .and yes heating mineral oil to the point it smokes is a bit dangerous not to mention flammable .and i did manage to catch my rig on fire while trying to chill the fog .it was a few tense moments but I kept my cool .turned off the propane supply and the fire burned it self out rather quickly .anyhow you shouldn't use it around open flames .that is even on the safety instructions on the fogger it's self .another thing you should not do is use any poisons in the fogger you intend to use to make fog .nor should you use an old fogger that was used for fogging poison
.i would NOT recommend using this inside .the fog isn't the best of things to breath but i would say its less harmful then smoking cigarettes .if for what ever dumbass reason you do use this inside you need to have a fan or three ready to clear out the smoke
i was using my fogger to see how the air moved around on our back porch .trying to figure out how to most effectively cool it and while doing so i the smoke had blown around my house and across the street leaving a hazy trail .i walked out the front door of my house and the neighbor from across the street was already on his way over to see if every thing was alright .i had to explain how i was just using my fogger
.the point of that story was that by using this fogger there is a good chance you might get the fire department called out .so using it will be done at your own risk
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:somebullcrap
