3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
tool belt heater
tool belt heater
I saw a short program (probably on one of the cable science channels)
about Canadian experiments on working in the cold. It showed a man typing
on typewriter in a 40-50F room with no gloves on. They explained that
the secret was that he had a heater around his chest that was keeping
his core temperature constant and warm. It seems that you body can
sense when you are losing heat from your body core and will actually
cut off blood supply to your extremities to keep your core temperature up.
Another program was shown recently on the Science channel called "Lost
in the Snow" that showed a similar experiment on the effects of exposure
to cold temperatures on the body.
I have used the Hometics heating pad around my chest to keep warm on
cold winter days indoors. However, there are times when I would like
to use it without being plugged into the wall. Hence my idea for a
portable power supply using a tool belt. Be warned that this is only
an idea that I have used for myself. Someone would have to manufacture
this with UL approval to insure safety.
By using something like this, people could lower their thermostats and
save fuel during the winter months. I used a lead acid battery
because they are easy to recharge and reliable for the cost. A lithium
ion battery could also be used, but they are much more expensive.
The battery can easily be swapped out and using several could extend the
time you can be unplugged. I believe the current setup should last
about an hour and quarter before the battery has to be recharged. The
Chicago Electric inverter will beep when the voltage from the battery
is too low. I use the battery adapter to connect to the inverter to provide
a fake "cigarette lighter" connection to the power inverter.
The power inverter can then be used in the car for the heating pad
(or any other purpose). Otherwise I would have
had to cut off the power inverters cigarette lighter connection to make
a connection to the battery. This also provides a quick way to disconnect
the battery in case of problem. This tool belt provides a way to keep all
the electronics in front of you in case of a problem. You could also use
a backpack to hold the battery and inverter if the weight around your
waist bothers you.
In the summer, you can take the tool belt heater apart and use the battery
and inverter for other purposes.
Step 1Make the battery connector
Make a connector for the sealed rechargeable battery. Cut off the alligator
clips and solder on the quick disconnect connectors that plug into the battery.
The power connector shown is an Optronics A-203. It has alligator clips on one
end and a "cigarette lighter" style connector on the other end. Be sure to keep
track of which of the two connectors are the positive and which is the negative.
On the A-203, the positive wire has a white stripe.
4 comments
May 2, 2010. 9:16 PMheathbar64 says:
 That's interesting. I would really like to explore this concept because I work outside all winter and it's a real pain to have freezing fingers all the time.
I remember when those Jone' liquid fuel handwarmers were popular, they offered a belt type thing with pouches to hold two of them on your lower back, but no explanation the the core temp or why they worked. Is the lower  back the proper place to apply the heat? You said in the earlier step something about the chest? How cold do you think a person could work say without gloves?  I was thinking of just using a heat storage thing that you microwave and it holds heat for a while.
Feb 5, 2009. 10:04 AMadmin says:
Usually you would, but I will update the status for you.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jtlien
