3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
tow in skateboard..
tow in skateboard..
i wanted to make a super fast skateboard for 'tow-in-skateboarding'. it needed to have much lower drag on the wheels than a small skateboard and a longer board, smoother ride, kind of wakeboarding/snowboarding feel. Here are all the parts and most of the tools i played with assembled before i begin. I had a carcass of an old beach skateboard to play with, which i ended up using almost nothing of. oh well. i like the way projects evolve.
Step 1Deck, super structure, trucks, wheels, tools.
an old piece of 80-20 is the stiff part of the board, the trucks are attached with a plate as you see. the huge wheels are from those cheap skooters. the scooter wheels can be found for 1-2$ each. because they are thin and have 100-120mm diameter they are WAY WAY faster than skateboard wheels. come to think of it i'm not sure why kids use skatewheels that have such small diameter.. the bigger wheels also ride out the bigger cracks and potholes so much easier, especially at speed.
55 comments
1-40 of 55next »
Mar 22, 2012. 11:01 AMilpug says:
Good first design, needs tweaks though, for sure. I must also be a complete jerk and scold you for going barefoot in the shop.
Feb 27, 2012. 5:08 PMBenjicg says:
pass the port to the left XD
port is red starboard is green
i knew that four and a half grand i spent on becoming a watersports instructor wouldn't go to waste
Jan 16, 2008. 4:29 PMDrawstreet says:
This is sort of painful, really look into this more. http://www.abec11.com/abec11-wheels-97mm-flywheels.php is just one of the MANY wheels made for Downhill longboarding (pushing 60 mph) A Scooter wheel is made out of terrible urethane and will not give you the necessary grip on pavement that a skateboard at high speed needs. if you are thinking of a SHORT board wheel they are small and hard due to the more "acrobatic" nature of the flips and slides performed.
Feb 24, 2012. 11:19 AMbenedict688 says:
Thank you, I swear i've posted 100 times about this, and people just still don't get it. roller blade and scooter wheels are made for roller blading and scootering, NOT SKATING. When you roller blade you can angle your skates so that you maintain traction while turning, skateboard wheels are always flat on the ground therefor you need wider wheels to keep traction. Theres 100 of different wheels in different sizes and shapes and hardess' that are all made specifially for skateboarding, and none of them look like roller blade or scooter wheels. Skating has been around for many years now, and there have been many advances in the technology that goes with it. Putting roller blade wheels on your skate is what they did 40 years ago before there were actual skate wheels. My advice to anyone whos putting these rediculous wheels on your board would be to check out a store that sells longboard gear, and maybe read an article about skating before you come on here and try and tell everyone how you came up with the best new way to make your skateboard faster, you just sound stupid when you don't know what your talking about
Oct 9, 2011. 12:14 PMTTAMREKRAP says:
Just for future reference the "centre bolt" that you refered to is called a kingpin
Oct 8, 2011. 9:26 PMYerboogieman says:
Reminds me of when we used to put rollerblade wheels on our skateboards and scooters. Much faster and lower ride height on the scooters.
Jan 3, 2009. 8:39 PMpinkhobo says:
skate boarders don't use big wheels cause it will give them wheel bite.
Jan 10, 2009. 4:30 PMberky93 says:
what is wheel bite
Feb 10, 2009. 10:07 AMjokerlz says:
Where the wheel hits the board causing it to stop suddenley sending rider flying forwards a few meters and then letting friction gravity and momentum do the rest.
Jun 7, 2009. 12:21 PMpyroman711 says:
long boarders do because if the wheels hit big rocks it deosn't make it stop because the wheels are just roll over them or push them out of the way and you don't really do many tricks on longboards where u lift the board so the board can be heavy skateboards only have small wheels so they are lighter so they can do tricks
Jul 15, 2010. 4:20 AMfoxtrot4697 says:
Longboarders use bigger wheels so that they can go faster and they dont need to be close to the ground like skateboards are because they wont be doing many tricks. they are also bigger to support the extra weight and because they can be bigger cause of the higher trucks
Sep 12, 2011. 5:58 PMpyroman711 says:
actually theres a whole style of longboarding that does tricks which is called longboard danceing like this http://www.youtube.com/watch?v=JTzvd6VSYMU they need to be a little bit thicker to take the weight spread out but i've had a longboard thats lighter than my skateboard so the weight doesn't have alot to do with how much weight it supports and the trucks aren't that much bigger i've seen freinds use skateboard trucks on longboards and with cutouts to not get wheelbite it works fine. and that guy is right they are lower to the ground so that they get less drag people go down mountains on longboards
Sep 11, 2011. 8:34 AMpero27 says:
oh yes we do :D
every longboarder tryes to have the board as close to the ground as possible; that's why the drop through design was born
if you are crusing you want to be low for ease of pumping and if you are dowhnilling you want to be low for stability and reduced drag ;)
I have a set of 82A 72mm rollerblade wheels on my cruiser for less resistance and they work just fine (they don't have any sidegrip whatsoever tho XD) - it's down to personal preference
but those trucks are a fair bit narrow; I use 220mm ;)
Jun 9, 2006. 4:47 PMXeracy says:
or use wider trucks. try Randle II 180s or like Indy 215s. also, having a large, heavy, stiff board is gonna make your ride sluggish, try cutting a deck out (of sturdy multi-ply wood, but not regular plywood) in the same basic shape as what you've already got, with narrow ends at the trucks to prevent wheel bite, i garuntee that it will atleast ride better :D
May 3, 2011. 9:41 AMjparry-1 says:
i made my own longboard in the same fashion as what you described and it only cost me about £10 and it works brilliantly i use it for cruising and it is going sturdy. all wheel bite is eliminated and its super smooth
Dec 3, 2010. 4:05 AMindalohouse says:
If you want to go fast the trucks you need are Randel 150DH these are designed to steer at speed, if its going to be under 30 then Randel 180's are the thing for carving. Either way Wide wheels are essential, ABEC 11's or WDM's. I use green Flashbacks . To give you an idea of whats possible take a look here, http://www.loadedboards.com/newsite_v1/ I have a vanguard as well as 7 or 8 other boards. I have nothing to do with this company but thier site is great, I suggest you look thorough thier videos you will be inspired to use the right kit and learn how to ride well, My final ford for you is Slide Gloves find out how and what they are for and you will increase your safty and boardcraft, im 48 and still riding strong. regards rob
May 13, 2010. 4:52 PMSqueekzilla says:
Its funny how much effort you went through to essential end up with A LONG BOARD. check this site out.
daddiesboardshop.com
Jul 15, 2010. 4:16 AMfoxtrot4697 says:
hmmm really? Skateboard trucks, scooter wheels, god knows what deck. supported by a piece of metal. doesn't fit the definition of a longboard
Nov 6, 2010. 10:24 AMjimbobaway says:
If you want to be technical, a longboard is just a long skateboard. Regardless of what wheels (they make 90mm skateboard wheels), deck composition (they make metal decks too), or trucks (Sector 9 and a lot of offbrand companies like to put shortboard trucks on their decks), it fits the definition of a longboard just fine. Constructive criticism to the design of this deck: Use wider, reverse kingpin trucks.
Oct 15, 2010. 11:31 PMbigbuties says:
the reason we dont use those wheels is they have absolutly no grip
Aug 29, 2010. 11:09 AMjustinazevedo47 says:
if you go long board trucks the turning radius would be much better
Jul 2, 2009. 5:48 PMsbent518 says:
Everyone's right, cheap truck and thin wheels are dangerous. I've had bad experience trying to save money, and AlloySkull is right, it isn't worth the bill. If you don't plan on turning much, the wheels arn't too bad, but still, ridding on flat land with my longboard with roller blade wheels, 72mms, i could still slip on simple corners. Get some ABEC11 wheels, some of those grip like none other.
Jul 2, 2009. 5:38 PMsbent518 says:
ah, there we go. Good ol' Locking nuts _
Jul 2, 2009. 5:36 PMsbent518 says:
You could also get some regular skateboard hardware, with locking nuts, that's what i've had to use with some ground down threaded bolts from the hardware store, works great. and riser pads are a WONDER in helping making the ride nicer, especially with the scooter wheels being so hard. This is really giving me some ideas for some of my own contraptions!
Apr 5, 2009. 12:32 AMYerboogieman says:
That means you have to loosen the trucks a bit, they are too tight to turn good.
Jan 14, 2009. 7:38 PMwak166 says:
the reason that you cant turn is probly because of the cheap trucks . if you got randal 180 longboard trucks this board would be awsome ! but it will set you back 50 bucks . if you dot have that get super soft bushings but it wouldnt wort as good
Oct 8, 2008. 7:11 PMadome says:
How did you get your hands on a waterjet?
Sep 21, 2008. 6:39 PMtrevyboy says:
nice foot
Aug 7, 2008. 4:00 PMcatwood says:
Where were you that you had access to a waterjet machine for cutting those ovals out?
Jun 25, 2008. 10:23 PMdigitalenigma says:
I feel obliged to point out to others i dont think its so much he cant turn on a dime, but more the 1,1/2 In dia. wheels are bitting the baseplate of the trucks (skateboard axels) designed for 3/4 In. wheels on turns? if thats not it just losening the king pin will give more turn radius..
Jun 25, 2008. 10:14 PMdigitalenigma says:
Yes that is why sk8rs dont use those inline fruit booter wheels! they ruin your turning radius unless you got monster spacers! btw, you could probally pull this off still if you add a set of old-old skool trucks the old vert ramp-ish type boards sported theese there about 1/2 to 2 In. longer than the standard trucks on todays street boards! Also looks like you got a set of 2 $ toys r us sk8board trucks which usally have a shorter truck width, are made out of sub-standard alloys (cardfull on the turns dude!) the ol-rustys probally would've functioned better but not looked nearly as clean/cool on the instructable! all that said it was a excellent project, and deserves a second go! good job man!
Jun 19, 2008. 9:26 PMAlloySkull says:
Take a hard enough turn on those going 30+ and you will see why that tiny surface area that actually touches the concrete does you no good. I forwarn you, some things are honestly better to spend some money on. Get some soft, large longboarding wheels, and some wider, stronger trucks. Independent 169s, Trackers of some kind, Randalls, Gullwings, Benetts, something.
40 dollars is nothing compared to a hospital bill. It's one thing to live dangerous, and another to live stupidly. So be smart and live on the edge, upgrade, you'll think yourself.
I've had kingpins snap on a hill. I've had bad nuts fall off (I had that thought that they never would) and I have got speed wobble so bad that I bailed out into GRASS and got a concussion, I hit so fast I wasn't able to roll myself. I tried to keep my head up but your neck can't stop momentum of going 30 down a "warm-up" hill.
Keep 'em loose on the streets, tighten 'em up for the hills. Remember, more speed = quicker response from your trucks. Speed wobble is hard to recover from and never believe you have power over what you are skating...
I've never had serious injuries because I take precautions. But I've been hurt when I shouldn't have been. So just a warning. Heed the knowledge of everyone here.
Have fun and keep longboarding alive.
Apr 27, 2008. 9:11 AMlaxman735 says:
this would be considered as a LONGBOARD!
Mar 23, 2007. 7:53 AMSoulFinger says:
Have you considered using riser pads between the truck and the metal plate? I think you'd find that the bolts would loosen much less as the pads dampen the vibrations a bit (even just the 1/8" size). You can also tighten them down to the point where the pad is being "squeezed" slightly which adds tension, further preventing the bolts from loosening. Also ... a smoother ride. Great design, by the way.
Feb 11, 2008. 6:13 PMNeilLizard says:
Yea, I agree.
Feb 6, 2008. 10:19 PMalvincredible says:
saw it in half, add hinges, and make it portable, like i did! ahah but don't make one like i did. it's totally gonna get you killed. ahah :-) good work.
Jan 16, 2008. 4:38 PMDrawstreet says:
the shape is fine, even the deck construction is good. A stiff deck provides a snappy response that most people at speed enjoy. More flex = more carve and cruise but a huge sacrifice of stability. better trucks would be more helpful.
Jan 16, 2008. 4:35 PMDrawstreet says:
a scooter wheel like that, especially combined with the rest of the set up is too high and unstable. a 60mm long-board wheel can reach higher speeds and is much more stable (due to the width)
Jan 16, 2008. 4:32 PMDrawstreet says:
http://www.randal.com/ if you're spending less than 20 per truck you are putting yourself in a dangerous situation.
Nov 25, 2007. 7:39 AMMad Hatter says:
You should put some grip tape on it. You can find it at your local skate shop for like five dollars a sheet
1-40 of 55next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
110
Author:saul
