turn signal biking jacket
Step 8Program your jacket
program your jacket
Decide on the behavior you want.
I wanted the left switch to turn on the left turn signal for 15 seconds or so, and the right switch to do the same thing for the right signal. Pressing a switch when the corresponding turn signal is on should turn the signal off. Pressing both switches at the same time should put the jacket into nighttime flashing mode. The wrist mounted LEDs should provide feedback about the current state of the jacket. Here's the code I wrote to get that behavior.
Program your jacket
To program your garment, copy and paste my code into an Arduino window and load it onto the LilyPad. You may have to make some small adjustments first depending on where you attached lights and switches. Play with delays to customize your blinking patterns. Follow my LilyPad introduction instructions if you need more information on how to program the LilyPad or how to make sense of my code.
Plug your battery back in and see if it works and...go biking!
Insulate the rest of your traces
Cover the rest of your traces with puffy fabric paint. Again, don't coat anything until you're sure it works.
About washing
Your creation is washable. Remove the battery and wash the garment by hand with a gentle detergent.
Note: silver coated threads will corrode over time and their resistance will gradually increase with washing and wear. To limit the effects of corrosion, insulate and protect your traces with puffy fabric paint or some other insulator. You can also revive exposed corroded traces with silver polish. Try this on a non-visible area first to see what it does to your fabric!
6 comments
Jul 31, 2011. 9:52 AMbeavercleaver says:
Very nice project, will it operate while rain soaked?
Nov 6, 2009. 9:41 AMShortedOut says:
Leah, are you still answering questions from your Instructables? I have seen many links out on the Internet, as well as the ones on this page, that are links to your University of Colorado Computer Science area. The pages you are linking to have apparently been removed from that site, which gives a Page Not Found message. Therefore, the code used to program this turn signal biking jacket is no longer available. For those people for whom this could well be a first project, the fact that there is no code available puts a damper on making a purchase of LilyPad products. Could the code be posted on this page, or is it too long? Thanks. I'll also send a message through the SparkFun site.
Nov 7, 2009. 2:41 PMannabelleolivier says:
You can find her code on her website http://web.media.mit.edu/~leah/LilyPad/build/turn_signal_jacket.html
Sep 23, 2009. 1:31 PMblurofred says:
What is your estimated cost for everything?
May 2, 2009. 1:20 PMMuratas says:
Creative, Great Idea
Apr 14, 2009. 7:59 PMWankaah says:
May I ask, do you feel the lilly pad on the other side? can you email me at t-g-l.crackelin.cracka@hotmail.com :) this is exiting
Dec 22, 2008. 12:43 PMDefault117 says:
Haha. You look like Iron Man in the last picture.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
107
Author:leahbuechley
