Step 4Cutting to size
measure in 2" and 2.75" from each end of all boards; find the center of the long boards and measure a 0.75" wide channel there; then measure a depth of 3.625" (half of the 7.25" depth of the board) on each notch. the shaded area in the fourth picture is what you end up cutting out.
we have a table saw, so it was quick and easy to make the two vertical 3.625" cuts, but a jigsaw or handsaw works fine too. you can snap off the remaining notch and might get lucky, but will probably have to clean up the cut with a chisel (or flat blade screwdriver) anyway.
note: err on the side of making your notches slightly too big rather than slightly too small - it will make assembly easier and gives some wiggle room.
Add Comment
