Two Piece Christmas Card on the Laser Cutter
2,167
4
Posted
Introduction: Two Piece Christmas Card on the Laser Cutter
I found this free design at the epilogue laser site http://www.epiloglaser.com and using drop box I uploaded and went to the TechShop http://www.techshhop.ws
Step 1:
The nice thing about the laser is that you can do a test run without any cuts. I was having a hard time getting two of the outline lines to be done. I finally figured out that they were guide lines which needed to be enabled using a drop down box on the right.
Step 2:
I set up the preferences on the machine - this was a cutting or vector project. Since I was using card stock I was afraid the suggested settings for matte board would be to much. I ended up needing to do two passes to cut through. So on the next ones I used the settings recommended for matte board and it worked fine. I would probably play around with speeding it up a bit to avoid the slight scorching that occurred, which might require a slight increase in power.
Step 3:
I also needed to work on the job start orientation - I was using a template for a page rather than the template of the laser bed. Once I overcame these problems, I let the machine cut.
Step 4:
Admittedly, it was a lot of time for a Christmas card. But I was at the TechShop http://www.techshop.com to learn and to lock in what I had been taught in class. I learned some things and it is a pretty cool card.
  • Sew Warm Contest 2018
  • Gluten Free Challenge
  • Minecraft Challenge 2018
