Introduction: Two Story House Playable With a Dynamic Model Tank
Picture of Two Story House Playable With a Dynamic Model Tank
The title gives everything away, but it is harder than it looks.
The idea is more of an inspiration for other broken houses, but you should build this one first as training.
Now, why would you want a broken house? So you can use it in a battle (or display) as a house that broke as a result of war.
In this hobby, a mistake blends itself in because the whole thing is a bombed mess.
You can drive your tank up onto this house and take pot shots on a tank in another house.
You can also buy "road", or long shingles (10 for 16$ at Rona).
The picture on the bottom is a certified plan (I'm not joking. my grandfather, blessed be he, certified it)
Step 1: Your Tools
Picture of Your Tools
Most of these tools are pretty common.
tools not listed:
-pens
-screwdriver
-candle holder
-anything that you deem necessary
Step 2: Supplies
Picture of Supplies
Supplies not shown:
-model tank (for measurements)
-foam board (optional)
-JUNK
Step 3: The Box
Picture of The Box
Take your box for oranges and, with the screwdriver and pliers (hammer if you need), disassemble it.
Step 4: The Roof
Picture of The Roof
take the floor tile and cut it along the "bricks".
Step 5: The Stairs
Picture of The Stairs
Take one shorter panel of the box for oranges:
-mark "stairs"
-cut them out with the x-acto knife
Take the other short side of the box and cut off pieces for the stairs (these should match your steps stairs)
Put the stairs (one at a time) flat on the groove in the vice (make sure you put it on the gap), place the bolt on top of the gap, and hammer away until you brake them to the desired degree.
Then get the corners for the next step.
Step 6: Making the Staircase
Picture of Making the Staircase
Put the stairs in between the corners to keep them upright as shown.
Stick the stairs on (if they're broken glue on a popsicle stick to keep them together).
The result is shown in the second picture.
Step 7: Part of the House
Picture of Part of the House
Take the cedar planking and cut it to the length of your tank (1:32 model=10 inches or 30 cm.).
glue the chopsticks to the corners, so it forms a rectangle.
Glue the cedar planking onto this rectangle. When it dries, cut 1 of the chopsticks away (where it stands out).
Step 8: The Ramp
Picture of The Ramp
take the sprue from the wooden model and snap, cut, or whatever it into small pieces.
Take popsickle sticks, toothpicks, chopsticks, broken sprue, and the two longest pieces of kindling wood and glue them together to make a ramp.
Step 9: The "garage"
Picture of The "garage"
take the bottom of the orange box and make lines joining the 4 middle holes together.
Cut this square out. Take the pliers and twist pieces of of the hole.
Step 10: Other Stuff
Picture of Other Stuff
Take a thick piece of kindling and cut it as high as one of the corners. Glue them as pilars onto the "garage" and then tie the garage to the main building with the metal wire.
Take a long box side and cut in a sort of wavy way. Take a piece of kindling and cut off 2 pieces for the side the tank will drive on from.
Then into the candle flame it goes.
note: the soot is caked on. It will come off if you wipe it
Step 11: Firing
Picture of Firing
Now you can "burn" the rest of the model.
Step 12: Constucting the Rest
I lost all the other photos.
Anyhow, I will still guide you through the construction.
there are two ways to continue:
(1): you can assemble the sides on your cutting mat, and then glue them onto the frame you can assemble with the skewers and wire (recomended).
(2): you can assemble the frame(as directed above), then you can build up from the floor (like i did).
Step 13: Details, Details
here are all the finishing touches:
-flame your model(if you did it like me,first hold the entire model over the candel, and char the outsid, then use a mixture of black paint and sawdust for the inside
-take a piece of the floor tile and cut inward, but not creating any separate parts. then take the pliers and rip the pieces off.
-use the plastic sprue and broken pens as pipes
-use the foam board as extra walls
Step 14: The End
Picture of The End
that's it! enjoy! get a tank! go play! have fun! KABOOM!!!!!!!!
see, it's a whole mess, but it adds a lot of fun!!!!
S1L3N7 SWAT (author)2008-12-18
Is this for those remote controlled tanks that you can "shoot" at other remote controlled tanks with? Or is it to display static(no moving) model tanks? You need to be a bit more clear in describing the purpose of this.
cutting Matt (author)S1L3N7 SWAT2008-12-19
I designed it for a radio controlled tank, but you can just use a static tank with it as a display.
S1L3N7 SWAT (author)cutting Matt2008-12-19
Ah,cool.
cutting Matt (author)2008-12-18
where did my yellow rectangles go on my pictures??
mikeasaurus (author)2008-12-18
Just a few comments: -Your instructions aren't clear to what you are trying to achieve here, only after investigating your profile and your forum topic was I able to understand what this was all about, don't count on many other people going the distance. A brief background would go a long way here. -You pictures are not detailed or well described. If you don't want to bother with the 'steps' maybe a slideshow just showing us what you built might be a better idea. Welcome to Instructables
About This Instructable
2,541views
1favorite
License:
More by cutting Matt:Fast clay jewelerytwo story house playable with a dynamic model tank
Add instructable to:
