Introduction: UCharge // a Revolutionary Charging Dock
Picture of UCharge // a Revolutionary Charging Dock
uCharge // A Revolutionary Charging Dock
uCharge is an innovative creation which is designed to primarily fit the needs of the consumer. This invention is a charging dock that features multiple chargers. It was brought to life by two freshman, Joe Hart and Connor Thomson, who realized that in a technological era, everything revolves around you and your electronical devices! Joe and Connor also realized that not everybody has the same devices; some people just have an iPhone, whereas others may have an iPhone, an iPad Mini, or a MacBook Air. They subsequently created a blueprint of a revolutionary charging dock that would give the consumer freedom and easy accessibility when it came to charging their devices. This revolutionary dock is simply a wooden box with PVC Pipes, a Power Adapter, Extension Ports, and a hint of creative thinking ;) uCharge helps the consumer charge their electronics by him/her the ability to personalize their charging dock based upon the devices they have.
*Please note that uCharge functions only with Apple™ products*
Step 1: Materials Needed to Build UCharge & Steps Necessary to Follow While Building UCharge
Picture of Materials Needed to Build UCharge & Steps Necessary to Follow While Building UCharge
Materials Needed to Build uCharge:
-Table saw
-Sanding tool or sand paper
-Drill
-Workbench
-Wooden box
-iPhone, iPad, and iPad Mini charging port, which is a PVC Pipe - The length of the PVC Pipe is up to you
-MacBook Air charging port, which is a PVC Pipe - The length of the PVC Pipe is up to you
-Three-outlet prong
-USB Extension Port
-One charging cord for each device (The iPhone, iPad, and iPad Mini don't need the USB Power Adapter)
-Wood Vanish of your choice
-Spray Paint of your choice
-Miter Saw
-Power Drill
-Plunge Saw/ Bone Daw
-Die Ginder
-Razor Knife
-Philip Head Screwdriver
-Hammer & Center Punch
-Nail Gun
-Bit 11/64 for Screws
-Bit 3/8 for Plug Holes
-Bit 1/2 to champher the Plug Holes
-File
*Below is a List of Where You Can Find the Necessary Items and How Much They Will Cost*
Michaels:
-12X9 Wooden Box w/lid $8.65
Ace Hardware:
-¾” Schd 40 PVC Pipe – 2’ $1.38
-1” Schd 40 PVC Pipe – 1’ $.69
Home Depot:
-36”x3/4”x1/8” Zinc Flat Bar $3.52
-8 8-32x3/4” Machine Screws $1.18
-8 #8 Washers $1.18
-8 8-32 Wing Nuts $2.36
-16/2 8’ Power Cord w/no Plug $7.58
-15 A 125v 3-Wire Connector $3.29
-Miniwax Polyshades GLS $7.98
-2” Utility Brush $2.97
-3 Gang Electrical Plug $1.38
Hobby Lobby:
-Small Silver Spray Paint $3.54
-Flat Black Spray Paint $3.54
eBay:
-4 Slot UBS Chargers $14.99 each
*THE TOTAL WILL VARY DEPENDING ON WHETHER YOU HAVE THE DESIRE TO ADD ADDITIONAL ITEMS TO YOUR PRODUCT*
Necessary Steps to Follow When Constructing uCharge:
1. Create a Jig to safely cut the pipe using your Table Saw
2. Cut the pipe to fit the devices with your Table Saw and Jig - Cut the pipe a little bit larger than the device's width
3. Cut the Band Iron with a Die Grinder to reinforce the Device Mount - Make sure they fit the inside of the box
4. Drill all the holes using a 11/64 Bit Power Drill
5. Assemble the Device Mount using #8-32x5/8 Screws and Wing Nuts
6. Notch the box for the Plug using a Plunge Saw
7. Drill a hole for the device's Power Plugs using the 3/8 Bit, or use a Drill Bit that is about the same size as the device part of the charger if the devices are Apple ™ 5th Generation or newer - Use a 1/2 Bit to remove the sharp edges from the steel by lightly drilling it
8. Cut a square for the laptop on side of the box if needed - At this point you can disassemble your box and paint the PVC Pipes/wood
9. Attach the Plung Saw to the back of the box using a form of adhesive
10. Add all the wiring and neaten the cords in the inside of the box
11. Add feet to the bottom of the box
Step 2: Making the Jig
Picture of Making the Jig
Step 3: Cutting the PVC Pipes
Picture of Cutting the PVC Pipes
Cut the pipe to fit the devices with your Table Saw and Jig (The PVC Pipes should look like a "c") - Cut the pipe a little bit larger than the device's width
Step 4: Grinding the Band Iron
Picture of Grinding the Band Iron
Step 5: Drilling
Picture of Drilling
Step 6: Assembling
Picture of Assembling
Step 7: Notching the Box
Picture of Notching the Box
Step 8: More Drilling :)
Picture of More Drilling :)
Drill a hole for the device's Power Plugs using the 3/8 Bit, or use a Drill Bit that is about the same size as the device part of the charger if the devices are Apple ™ 5th Generation or newer - Use a 1/2 Bit to remove the sharp edges from the steel by lightly drilling it - Then, add charging wires.
Step 9: Disassembling and Painting
Picture of Disassembling and Painting
Cut a square for the laptop on side of the box if needed - At this point you can disassemble your box and paint the PVC Pipes/wood (We painted the PVC Pipes with Spray Paint and the actual box itself with Wood Varnish)
Step 10: Attaching the Plug
Picture of Attaching the Plug
Attach the Plug to the back of the box using a form of adhesive
Step 11: Wiring and Organizing
Picture of Wiring and Organizing
Add all the wiring and neaten the cords in the inside of the box (We tied all the wires with Zip-Ties...They seem to work the best)
Step 12: Final Product!
Picture of Final Product!
Once you have done all these steps, your project is complete! ENJOY YOUR REVOLUTIONARY CHARGING DOCK!
Step 13: The Creators' Sign-off
Picture of The Creators' Sign-off
Both Joe and I hope you enjoy this product. We made uCharge with the intention of letting other people throughout the world join in on the action and have a revolutionary charging dock for themselves. Therefore, we wish you the best of luck on your journey to build a uCharge and hope it comes into handy for you for years to come. Once again, thank you and enjoy!
Happy Building,
*Please be sure to view and favorite our product and leave us comments!*
*IF YOU HAVE ANY FURTHER QUESTIONS, DIRECT MESSAGE ME ON INSTAGRAM @connor.thomson*
seamster (author)2014-12-12
Hey, this looks pretty handy. Thanks for sharing your cool charging dock!
uCharge (author)seamster2014-12-12
no problem. Glad you enjoy!
JCouture18 (author)2014-12-12
attaboy big CT!!!!! D1 bound technologically!!
About This Instructable
1,922views
18favorites
License:
Bio: Joe Hart and Connor Thomson are both 15 years old and are freshman at Brophy College Preparatory.
More by uCharge:uCharge // A Revolutionary Charging Dock
Add instructable to:
