3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
umbrella light
Step 2Disassemble LED flashlight
This particular LED flashlight style separated into the housing and clicker half, and the light assembly half. You're going to need everything except for the housing from both halves.
back half:
  • battery pack
  • on/off clicker
  • (-) lead from clicker to negative terminal
  • battery housing and handle
light assembly half:
  • LED array (+ terminals)
  • reflector
  • housing
2 comments
Nov 15, 2009. 1:28 PMJediLoreen says:
Cool idea with the flashlight, but yikes, why would you throw away what looks like a perfectly good 3 cell battery holder, when you could use it for another project if you needed to power something with 4.5 volts?
I guess not every prop builder is a pack rat like me.  ; )
Nov 22, 2009. 6:19 PMliedenfrost says:
Hey, I was wondering if you could possible add a small linear electric generator in the handle of the umbrella so that as you walk the linear motion(up down motion that the handle experiences as you walk) would light the LED's without the need for batteries, or it recharges the batteries as you walk, whichever.
and maybe while the umbrella is not in use a small coil of nichrome wire is heated by the generator so that the handle of the umbrella is always warm when you take it out of your bag/handbag. or indeed a means of  trickle charging your Cell phone with the small amount of juice the generator would be producing while in your briefcase etc.
So what do you think? want to go into business? hey if you use this info in a commercial capacity I demand a E0.42 cent royalty on all umbrellas with this design...Please.
But in all seriousness, it's doable right?
Linear electric generators: http://www.powergeneratorinfo.com/honda-generators/linear-induction-generator.php
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
763
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
