3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
umbrella light
Step 7Sock attachment and seam
sock attachment and seam
Start by attaching the truncated tip around the slider at the top of the umbrella. Then form the cone shape by taping the bottom of your cut-out to the handle.
Depending on the material you use the methods of closing the seam will vary. The material I chose is thin and melts with no trouble under the heat from the glue gun (no glue). Carefully and gently I was able to seam the sock shut, the seam may warp slightly but still looks good.
(I recommend practicing on scrap material first, it's very easy to melt right through the sock. An issue that is hard to repair and may compromise the awesomeness of your umbrella.)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
763
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
