Unicycle Arlequin
Introduction: Unicycle Arlequin
Kinetic Sculpture Design Contest
Second Prize in the
first make the draw of an mobile arlequin all the parts separated.
Legs, arms, shoes... and the monocycle.
Then mark those templates on an mdf. a 3mm and 9 mm wide.
Step 1: Cut the Pieces With a Jig Saw
cut all the templates with a jig saw. I use a stool thats have a hole at the center to sopport my cuts. And do it safely using gogles
Step 2: Making the Pedals
cut a rectangle of a wide mdf and glue the sneakers of the arlequin.
Step 3: Make the Center of the Wheels!
i had a wooden  wheel from a diferent proyect and i cut it in half.
I sanded and glue it between the two wheels of the arlequin.
make sure of pressing it for a couple of hours
Step 4: Making the Pedals
i did a similar thing with the pedals (cut it in half)
Step 5: Unicycle Seat
cut the templates o a wide and thin mdf
I attached the seat using a cheap drill (You can use a DREMEL brand drill) before nail it to the body of the arlequin.
Step 6: Add a Wooden Stick at the Center of the Wheel
Put glue before insert the stick.
I painted the wheel while the glue dries.
After it dried a carved both sections of the wheel where the axes goes.
Step 7: Continue Paintings
paint the seat and the axes before insert the wheels. then insert the wheel and glu the other axe.
Step 8: Glue the Pedals Axles
Make a hole on each center of the  pedal axles and glue them at both sides of the center of the wheels, be sure to the directions ... one going up and the other down
With a plier atached the parts.
Step 9: Go Crazy Paintings the Parts
Step 10: Attach All the Parts Together
i use paper clips that i opened and cut in half. I curl the ends with a plier
For the pedals i put a plastic part. I dont know its real name or use, but i found it in a woodstore, maybe its use on furniture making.
Step 11: Juggling Balls
using the drill (same as a DREMEL brand) i made some holes in a balls. I had it before, for necklaces. And do holes at the hands and legs of the arlequin.
Glue the juggling bali in a wire that goes on the holes..
Step 12: Watch It Goes!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    The WMV did not work for me. I really wanted to see it in action as well. Can you make it go please?
    Very nice...
    Brilliant colors.
    Now you need a long stick with a ball on the end.
    Attach to his head.
    Then you can walk behind it!
    Looks GREAT!
    oh beautifulllll !!!!
    I loved it.
    so beautiful!!!!!
    love the colors, love the idea, love the whole thing!!
    hope you win this contest :)
    Great result, I like the vibrant colours.
    Nice project!
    This is really cute, nicely done!
