first make the draw of an mobile arlequin all the parts separated. Legs, arms, shoes... and the monocycle. Then mark those templates on an mdf. a 3m...
i had a wooden wheel from a diferent proyect and i cut it in half. I sanded and glue it between the two wheels of the arlequin. make sure of pressin...
cut the templates o a wide and thin mdf I attached the seat using a cheap drill (You can use a DREMEL brand drill) before nail it to the body of the ...
Make a hole on each center of the pedal axles and glue them at both sides of the center of the wheels, be sure to the directions ... one going up and...
using the drill (same as a DREMEL brand) i made some holes in a balls. I had it before, for necklaces. And do holes at the hands and legs of the arleq...
Bio:My name is Carolina and i´m a school teacher. I teach visual arts and technology. I also have a "nano" company called "maravillas en papel mache" you can see my works at http://www.flickr.com/photos...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
