3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
usb christmas lights
this project was inspired by the following web page:
http://www.i-hacked.com/content/view/62/44/
that said, there are unlimited numbers of things that can be powered by usb. with the holidays coming up, why not christmas lights? i've added a switch to the original design to allow me to turn them on and off without unplugging the usb cable. The whole thing is mounted into an enclosure (altoids tin, of course), purely for aesthetics.
Step 1Get your equipment
get your equipment
i began with a battery operated set of christmas lights, and the male end of a usb cable. i cut off the c battery holder, taking care to mark which wire was positive and which was negative. frankly, this may not matter in this case, but i wasn't completely sure, and i'm a better safe than sorry kind of guy. i stripped the ends of the wires and twisted them to keep them together. i then stripped the outer sheathing off the usb cable and located the red and black wires. these are the only ones we will need. if you're following along with me, strip them too. for an enclosure, i chose--of course--an altoids tin. this, however, is the first project i've seen inside an altoids smalls tin. (at least that's something)
oh, i also use a small toggle switch and some solder and what not.
34 comments
Jan 8, 2010. 2:41 PMhi111 says:
 i am a 12 year old electric novice and would like to now if someone could tell me how to wire a 5v regulator in this schematic
i already have it built and it charges my psp but i am making it able to charge my ipod and think a $2 regulator is worth less than a psp or ipod
Aug 4, 2010. 11:17 PMcdousley says:
here you go im 14 and love electronics its great to see younger people into buildings stuff
Aug 5, 2010. 1:58 PMcdousley says:
: D
Jan 10, 2010. 11:33 AMBluePhenox says:
(removed by author or community request)
Jan 8, 2010. 5:56 PMhi111 says:
 thanks that helped alot
Aug 4, 2010. 11:19 PMcdousley says:
ohh i didnt see where this was answered but i hope i helped a little
Nov 22, 2009. 1:01 AMiProton says:
 I'd also give it a tumbler switch or a dimmer :P Just in case.
Oct 25, 2009. 8:04 PMmatroska says:
 Very neat! I'll be using this to power my ipods and iphone!
By the way, for those looking -like me- to power real usb devices, you will need some modification made so that the device will know it's a "real" usb port.
See this instructable for more details:
www.instructables.com/id/How_to_get_your_iPod_to_charge_with_your_homemade_/
Unfortunatly, as is, it will not power iPods or any other devices that requires some kind of usb standard. (Which is why in that instructables all the 4 pins are used.) Good luck all and thanks.
Jul 26, 2008. 3:25 PMSk8erCk4Life says:
Can you use a set of christmas lights and power them with a pc.
Feb 23, 2009. 8:16 AMboyrock375 says:
it could be possible if you can find a way to turn 5 volts into twelve volts then you can use an inverter to turn twelve volts into 120 volts then TA DA.
Mar 23, 2008. 8:08 PMTheInventor says:
Quote pdub420:i've used white electrical tape to insulate the soldered ground wires. color doesn't really make a difference, but please, please! don't EVER use red!! just kidding.|| That was hilarius!!! +1
Nov 11, 2007. 5:17 PMled235 says:
how many volts come out of a computer USB Socket?
Jan 15, 2008. 10:00 PMquanta says:
5 Volts
Oct 18, 2007. 8:31 AMKa - X japan says:
could you makes this work with music on your computer?
May 16, 2007. 4:05 PMYerboogieman says:
Here it is....
Mar 4, 2007. 7:24 PMYerboogieman says:
i mad this battery pack...
http://www.hackaday.com/2005/01/20/how-to-make-a-usb-battery/7#comments
the battery is only a little warm but im not sure about it.....and i made the usb christmas lights with the same everything...its pretty kool...the battery pack on this instructable got me interested...
Mar 3, 2007. 10:15 PMnerdsrock007 says:
Didnt you think about other uses to this? This could be the neighborhoods best halloween pumpkin.
Dec 11, 2006. 9:00 PMrbhays says:
I would test the lights before I would hot glue them in place lol. I wonder if the lights will last longer since there is less power going through than normal?
Dec 2, 2006. 8:58 PMzachninme says:
On the x-mas lights, why did you use the tin? You just spliced 2 wires...
Nov 3, 2006. 2:42 PMFog says:
i dont get it! why go through all that troule, if ur gonna use another battery!!? :S
Oct 27, 2006. 11:31 AMtrebuchet03 says:
Nice work :) --- Looks like a basic 5v power supply -- if you want something more efficient, search for the mintyboost by ladyada ;)
Oct 26, 2006. 11:50 AMatombomb45 says:
Nice. I like the battery pack too.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
79
Author:pdub77
'eclectic' is a good way to start. . . I like to build things, make things, take things apart and mod things. No matter what, though, humor is the best medicine. And I can't believe how many times I...
more »
