USB powered plasma globe!
This instructable has been removed by the author.
39 comments
Feb 13, 2010. 4:19 AMLittle Einstein says:
Good one IW5
Sep 25, 2008. 1:33 PMJosho says:
This should be called "How to run battery powered toys off of USB power" or something.
Sep 25, 2008. 2:11 PMjakee117 says:
yeah that's pretty much what it is
Jul 25, 2009. 4:04 PMtake.n.make says:
True, but this method can be applied to so many different items that it would be beneficial to encourage people to find it without specifically looking for "plasma globe."
May 15, 2009. 4:57 AMsoftairdude says:
wow
Mar 14, 2009. 3:26 PMN1CK4ND0 says:
Pretty sweet Instructable!
Dec 29, 2008. 9:03 AMXellers says:
This works, but it isn't a very good idea. I noticed that you left the plasma ball's citrcuit board sitting on top of the battery holder. This is not a good idea because if you are grounded (and you are unless you are wearing incredibly thick rubber boots and gloves), then the high voltage output to the globe could arc over to your finger if you put it close. Put this in a case or something.
Feb 8, 2009. 11:00 PMAmberwolf says:
It actually originally ran on 6 volts if the battery case is wired like it looks (1.5V x 4 batteries).
But despite what it is *powered* from, the plasma globe portion itself is a high-voltage device, and can indeed be dangerous to touch the portion of the circuits that power the wire going to the center of the globe. There is not much (if any notable) current flowing there, but the voltage itself should be several thousand volts.
So be careful--while it might not kill you, it could hurt. ;)
Dec 31, 2008. 4:45 PMXellers says:
These things aren't deadly, I guess the reason that you touched the circuit board without being shocked is either luck, or that the plasma globe was drawing so much power. But it still doesn't make sense... Maybe you just didn't feel it because of the skin effect?
Jan 1, 2009. 9:35 AMXellers says:
Two dollars?! I want one!
Feb 8, 2009. 6:57 PMMach5 says:
Don't get your hopes up Xellers, I've looked in four wal-marts and one target in the last year without finding any battery powered plasma globes at any price.
Oct 11, 2008. 11:21 PMcarrierpilot1357 says:
¡İlqP‡Tny‡su1 İT1u c'mon, you know what I typed. By the way, Ù‡x݇ uop İp1sdn İ1l ‡sn~ 1 Ùƒu1e‡uP yo İo~ P ‡ou s1 s1e‡. And I really mean it, Nice instructable!
Sep 26, 2008. 6:12 AMPKM says:
"Ohio" = "you how"?
Idaho ld on to this nugget of information- the top left spring contact in the battery box is the negative = black wire, the top right flat contact is the positive = red wire. If you trace the wires that were Oregonally connected to those contacts you won't have to risk connecting the power backwards and potentially damaging your device, and that's the Maine thing (though I have a Tennesee to ignore my own advice here).
Nothing sounds like "South Carolina" enough to work into this pun
Dec 2, 2008. 9:29 AMDerin says:
,,Example,,
turns into:
Example
Hope this helped!
Dec 5, 2008. 10:03 AMomnibot says:
That's a very small "thank you".
Nov 28, 2008. 3:30 PMpls says:
cool!!
Nov 28, 2008. 7:23 PMpls says:
Oct 1, 2008. 11:37 PMMach5 says:
Where did you get the toy for 2 dollars?
Oct 1, 2008. 6:43 AMPlasmana says:
This s cool! I used to have a USB powered plasma globe, but I modified it to be battery powered!
Oct 2, 2008. 5:09 PMPlasmana says:
LOL! Yeah..
Sep 25, 2008. 8:00 PMgmoon says:
Yeah-- take that, Ohio!
Sep 25, 2008. 3:33 PMKaptinScarlet says:
cool, quick work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
18
Author:IW5 Industries(IW5 industries.com)
Hi I am an inventor who owns the company IW5 Industries. A company that repairs a tractors in the summer, and mass notification devices any other time. I actually work part time at my local EMA with t...
more »
