Introduction: Usb Storage Box
Picture of Usb Storage Box
the materials what i used are as follows, others can be used alternativley
a small plank of mahogony board 5mm thick
pva glue
2 nails 2.5mm in diameter
the tools i used are as follows (i just used what i had at my disposal)
coping saw
junior hack saw
modlers vice
pencil
sand paper
files
a hand drill with pilot hole drill bit and a 2.6mm drill bit
ruler
set squar
a small G clamp
just as a note, i havent got all the suplies in the picture, it is more of general toold and suplies
Step 1: Making the Box Sections
Picture of Making the Box Sections
first of all i took my piece of wood, then i marked out the exact pieces i needed to make the box with my ruler, pencul and set square, in this planing make sure to leave room for cutting as the blade will take up some of the space.
then cut the pieces acordingley
and then sand the sides of the pieces untill smooth and of accurate size.
in this section you can choose the type of joint you want to use for the box, i used a but joint, this is a weak joint, but you can youse whatever joint u desier depenting on what u want to do and how much time you have.
Step 2: Glueing the Box Together
Picture of Glueing the Box Together
i got all the pieces of the box together exept for the lid piece
and assembeled them before glueing to double check they were corectley sized.
i then glued the pieces together to form the bog with the but joints. i secured the box in my vice and also with a G clamp untill the box is set.
PVA glue takes 8 hours to set but it is dry to toutch in 2 hours and stiff to work within 6 hours, but that is my guideline as i dident use a watered down mix.
Step 3: Making the Lid Mechanism
Picture of Making the Lid Mechanism
i started off by drilling a pilot hole into the sides of the lid and into the place where the lid is going to be secured to the main body of the box, then i went through the hole with the larger drill piece.
i sanded a curvature into the lid to allow movement in i.
then i cut of the ends of 2 nails with the junior hack saw, these pieces will fit into the holes on the box and through the lid section and this has formed a lid and has fulley secured it to the box itself as they cant be taken out easley.
if you wanted you could hide these pieces of metal by using the saw dust mixed with pva and placed over the nail and it should act as a filler to hide them.
Step 4: Finished
Picture of Finished
now you can stain your wood, engrave an image or name onto it
but mainley it is ready for storing your USB memory stickes insyd it away from plain sight
this is a greate litle storage box that could be used to gift a usb in
now be creative with my idea and make ur own  =D
lemonie (author)2010-06-20
That's quite a nice box.
L
full_metal (author)lemonie2010-06-24
thank you verry much :)
lemonie (author)full_metal2010-06-24
(It's good so see some wood being used, heck you could have put it in a mint-tin...)
L
full_metal (author)lemonie2010-07-04
that would be a good idea, could solder in place some pieces of sheet metal form a bean tin to have indavidual compartments.
lemonie (author)full_metal2010-07-04
That is a good idea, but not solder (it doesn't work very well). If you folded the metal into square-sided "cups" with the sides bent out at a slight angle they could hold on to the box with their springiness.
L
that is a good idea, but i like my solder idea, i would do it by puting a slight set of holes along the length of the sectioning bits and pudle the solder, i find that to be a good method, but it would take longer and requier a jig and to be smothed of afterwards.
I've soldered cans but it is a bit difficult. Slot them perhaps?
L
ok, mabey another time il post an instructable on how to join bits of tin with solder :)
That'd be a good one to do, so yes.
L
ok then il get on it, i just need to wait until i get sutibal materials to do one
Kaelessin (author)2010-06-28
heh brilliant! ancient rustic wooden box holding super techy cyberpunk gear . . .visual irony pulled off quite well!
full_metal (author)Kaelessin2010-06-29
i think it works quite well
About This Instructable
2,942views
11favorites
License:
More by full_metal:usb storage boxcyber punk USBchain mail lamp
Add instructable to:
