3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
usb wifi antenna
Step 4To get a better signal push it in about half way!!!
to get a better signal push it in about half way!!!
4 comments
Jan 6, 2009. 2:12 PMcatsnw says:
how far do these work
Sep 29, 2008. 10:26 AMgoggomobil says:
I don't see where the reflector is bonded to the USB's chassis ground... is that necessary?
Aug 26, 2006. 5:35 PMmanuka says:
(removed by author or community request)
Feb 26, 2007. 7:40 PMcocotower says:
This guy with the strainer dish isn't kidding, and you'll be shocked when you see how simple other dishes or cantenna ideas can be used as well with the same adaptor. What works GREAT for me, even as I type this teply is the same Belkin Wireless USB adaptor stuck through a slot in the side of a Maxwell house coffee can. If you can't pull off doing this cut work, use a Pringles can. It works great as well for picking up a distant remote network which otherwise wouldn't even show up on the network site monitor. Ofcourse, by trial and error you have to find the remote source by pointing your "radar" around until the signal shows up loud and clear. You're basically concentrating the outgoing microwaves from your adaptor into sort of a flaslight beam towards the source which sees their signal as well due to how antennas work, BOTH WAYS. That is, antenna reception boosters also boost transmission power.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
4
Author:wombat7
