this type of DIY solar panel is the most sealed from water. I have made wood frame and all seem to get moisture in them. I still make them but they are good under a roof or eve .
This diy solar panel was made with all cracked 3"x6" solar cells to see if I could get the same power out of them, on the next steps I will show what all I did. http://sites.google.com/site/earthforsolar/glass-frame-diy-panel
looking for solar cells www.solarcells101.com
Remove these ads by
Signing UpStep 1Soldering tabbing wire on solar cells
I will cut two pieces of tabbing wire 6" long. Then I soldered all the backs first. http://sites.google.com/site/earthforsolar/glass-frame-diy-panel
On this set of solar cells I used cells that were cracked all the way across, I soldered the tab wire on the back first then I used packaging clear tape and taped the bottoms. This made the cell stronger and helped to keep them from braking more in the soldering and diy solar panel making process .
Because Commercial Panels as so expensive
It will take you 10 years to break even on commercial solar panels
Look at this diy solar panels website that calculate it
I have made the same panels as you but put them in an aluminum frame on top of 4mm toughened glass. I've then encapsulated them in clear epoxy resin. Have had them on the roof for over a year with no problems so far.
