3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
using Solar Cells, To make Glass frame DIY Solar Panel
Step 2Soldering the rows of solar cells in series
soldering the rows of solar cells in series
Materials you will need when building your panel.
* Multiple solar cells
* Ribbon or Bus wire 5mm
* Wire cutter/stripper
* Soldering iron 15-25 watts
* Rosin core solder with non-corrosive flux (best for the value)
* Tab wire or solar cell tin wire 1.5mm or 2mm
If your having problems soldering your solar cells your soldering iron could be too hot
I only use around 20 watt to 40 watt iron  and the only thing I use is rosin core solder
60/40 with flux in it  it works great and melts at low heat http://sites.google.com/site/earthforsolar/home
Need solar cells this is my website  http://www.solarcells101.com
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:EARTHFORSOLAR(solarcells101)
I love solar energy and building homemade diy solar panels, that is why i put together a solar diy free E-Book at sites.google.com/site/earthforsolar and a solar and wind forum at http:...
more »
