using USED COOKING OIL for survival candles by aworkofbart
Once we all used to throw away USED COOKING OIL, but now the word is spreading that it's a good source of fuel.  Since the last good old-fashioned ARKANSAS ice storm I lived through, I have been experimenting to find an easy way to reuse the stuff for candles and heat so that I can prepare for the next ice storm or 2012, whichever happens first.  After you use the oil for cooking and it's cooled off, line a funnel with a paper towel and pour it back into the bottle it came from for reuse.
ANY TYPE OF NEW OR USED COOKING OIL CAN BE USED.  I have tried oil candles with everything from BRAND NEW olive oil to the cheapest stuff I can find that was used to fry FISH and it's all the same.  A USED COOKING OIL candle with a properly adjusted wick makes NO SMOKE and NO ODOR.  There will be a wisp of smoke for 2 seconds after you blow the flame out that will have a faint odor of what was cooked in the oil, and if you push the wick into the oil to extinguish the flame there won't be any smoke at all.  USED COOKING OIL is the only fuel I have found that will NOT stink up your house.  There is the $40 / gallon ultra refined parrafin oil that promises less odor than normal parrafin lamp oil - I can't afford to stockpile that, but I can afford to buy and use and save cooking oil and reuse it for FREE.
One of the simplest ways is to use something shallow like the bottom of a pop can - you can even use one that's been crushed.  Cotton string, candle wick, even a rolled up bit of paper towel will work as a simple wick.  Use a matchstick to adjust it (push it around to have more or less of is hanging over the edge) so that it's bright but doesn't smoke.  ANYTHING THAT USES LIQUID FUEL WILL MAKE SMOKE AND SOOT IF IT IS OVERFUELED.  Because of its viscosity, USED COOKING OIL doesn't wick upwards very well so the device has to be very shallow.  You will have to monitor it frequently or it will run out and extinguish itself.  AS WITH ANY OPEN FLAME, CANDLES ARE DANGEROUS AND SHOULD BE USED ONLY WITH GREAT CARE.
Mr.1911 says: Apr 17, 2012. 3:41 PM
I'm definatly going to make one of these. Would the bottom of a soda can cut off work? Say, cutting it about a third of the way up the can and using the bottom part as a cup to hold the oil? Great ible by the way!
aworkofbart (author) says: May 2, 2012. 7:02 PM
this method requires a very shallow container, so if you were going to use a 4 oz. container you might have trouble getting your wick up over the edge and staying lit
meddler says: Mar 14, 2012. 11:09 PM
Cool, I have been thinking of the same thing. This info will come in handy, thanks.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
