Remove these ads by
Signing UpStep 1Take a five gallon paint/pickel bucket and cut a hole in the bottom
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
I actually use:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=92475
and whats nice about it, is it is indestructable. I'll put the entire unit in a bucket, put the vacuum port into the thing I want to suck from, and it deposits the oil/water/etc in the unit, where it drips into my bucket. It pulls a strong vacuum too. Dirt cheap if you have an air compressor.
Assuming you can keep your plastic from collapsing, place unit outside for a half an hour and let it get up to say 70-80 degrees, pull 29" of vac, and the water will boil off.
The key to this working is whether the bucket survives and you can pull 29".. A home vac will not do this.
http://www.mcgillairpressure.com/vac/textdocs/aboutus.html
You're not going to get a lot of extra drying from that level of vacuum. To seriously vacuum-dry things, you need a vacuum pump. (Like maybe this one I made from a tire inflator: http://www.instructables.com/id/E791HNXF23Z39P6/ )
If there's much water, your vacuum pump will have to pump fair bit of volume, because water expands tremendously when it vaporizes. (So don't expect a little vacuum pump to dry big things very quickly. Thoroughly, yes; quickly, no.)
