DOES YOUR MOTOR HAVE A GAS TYPE CHAIN /BELT TENSIONER?
Does your head have adjustable valves
Does your head or motor have hydrolic tappets"?
Can you afford a Head Gasket set if so how much can you spend ?
Are you using a used replacement head is it rusty ?
Have you ever worked on cars motors or lawnmowers ?(expireance)
How complex is your engine is it a simple old chevy or ford or : is it a newer OHC with variable
timing ( these can be tricky)?
Do you have enough Tools to remove the head sometimes special sockets for torx type bolts
Remove these ads by
Signing UpStep 1Get ready to grind heads HAH!
CONSIDER DO YOU NEED TO GRIND VALVES ?
A . to begin with do a compression check and note what cylinders are low 20 or 30 %,(example some are 85 and some are 120 lbs.) AND THEN
B .examine the movement of the valve lift before deciding to remove head see? if valve motion is moving like the higher reading cylinders valves,? movement look good" is the cam worn off? if so fix cam first
Is or has the valve clearance become too tight (by adjustment or wear?)if so "adjust if possible first ....see notation #2B down page below (then recheck compression)
IF AND WHEN YOU DECIDE TO GRIND VALVES
ON OVERHEAD CAM MOTORS YOU PROBABLY WILL NEED TO TAKE THE CAM /S OUT 1ST
engines with pushrod motors (not overhead cam) i recommend caution if loosening any rockers are removed as some motors like chevy v-8s and inline 6 motors have a certain way to set them ARE ROCKER ARMS IN THE WAY OF HEAD BOLTS?
when you remove any rocker arms pick one and determine(count as you loosen) how many turns the nut takes to be loose enough to get the socket squeezed into the head bolt then use this figure to turn any outher rockers(when loosening). I usually only take as many rockers loose as i have to and then tighten them to the exact same amount of turns as you used to loosen the rocker arms (better a fraction loose then over tight)
1.To begin remove the head then clean it good
2. remove the valves springs ( use tool or make one)
3.place valve springs in box in a line maybe number the springs
leave the valves in the head in the same holes ( do not mix them up)
after this see if you can wiggle the end of the stem where it sticks through( valve guide) the head sideways if 1or two are really loose like .020 thousands beware you may to need have a guide installed at a machine shop for like 10 dollars o.k.?
4. place head on bench or piece of wood have a few small piece's of say 2x4x10" wood handy
5.hook up hand drill 1/4" or 3//8" best, too a suitable plug in a drill that can? run slower than 800 rpm is better i recommend 300 rpm is best
6. determine the size of the valve stem 1/4" or 5/16" 0r 9 MM. go to auto store buy the size of neoprin gas line that will squeeze onto the valve stem diameter tight or snug no more then 4 to 6 inches needed for several grinding job o.k.? cost around 1 dollar
7. get a small wood dowel or saw the end off a soft bolt 5/16" to say 3/8" it should be 3" long or 4" long ( nearly always)
8. take time to clean the valves one at a time if they have carbon caked onto them like wise remove any gunk carbon or rust from around the immediate area of the seat,it helps a lot when grinding
9. don't clean bent valves take them to auto store buy new ones for about 8 dollars each
10. if the car / truck ran good( 4 cylinders) and didn't backfire the intake valves may not need grinding, if v-8 engine they probably do so look at the faces and stems if there bright and show no signs of pitting maybe just grind the exhaust valves o.k.? used intake valves make better millage than freshly grinded ones do
11. if the exhaust valves are burned bad they may need to be faced/ if there usable at all and to help with keeping efficiant grinding time.
12 . i do not reccomend buying all new valves as the installed height sometimes need to be set (so use original valves if u can)
and it is nessessary to have the new valves Stems grinded to be the same length as the old ones
so using the old valves might be better unless you know what your doing o.k.?
notation #1Exhaust Valves
BE IT Known !!! that exhaust valves get hotter :..and will wear ,or burn faster than intake valves: and therfore.. are to be expected" to be more likely to leak (power loss) and also and or on occasion be be bent dew to timing jump" if your motor is an >interfeirance type motor< (ask auto zoin )
BUT if YOUR Valves are bent you will still be able to fix your car / engine:you just have to buy new valves, and follow these same methods after installing any new valve it will have/ need to be adjusted to the right length"... pay attention... to factory valve lash specs: if so.
***** notation # 2B Are Valves too tight (learn how to set em)
what i am cautioning is to be aware > how tight a valve assembly is / or has' become: <
This tightness or shall we say over tightness is something called >Lash"< or Stem end clearance.
* CHECK VALVE LASH WITH EACH CAM LOBE ON ITS BASE CIRCLE*
Checking this (lash) is sometimes simple" :on non hydrolic lifters or barrel tappets a quick check
i will mention is simple checking to see if a tiny space is measureable between the
tappet or in some cases cam follower /rocker arm all non hydrolics require a small space
in the line of lift force it is there to compensate for the expansion of hot valve
stem expansion " it (the space mentioned valve lash") it can be .006"(six thousands)
an inch.or it can be .010"(ten thousands) or rarely more,
ok if the valve is over tight it will hold the valve open" and that will cause a low compression(psi)
too mention futher the effect
of said over tightened valve lash include 2 symptoms low/r compression and :
if on the intake valve : this causes backfireing into the carb or intake manifold (fi eng-plenum)
on the outher hand an overtightened exhaust valve will become overheated
and that is very bad as more damage will concur as result!
knowing if a hydrolic lifter or hydrolic valve adjuster is too tight is a little more complex
let me say check any adjustment nuts if thar are any as these type of settings are often discribed as non adjustable that is not to say they cannot be adjusted or even rarelie become to tight occasionally ok..................to explain takes time
just try to see if you can compare any differance to any of the normal compression cylinders... If your car isnt (didnt) miss or backfire and has hydrolic lifters or adjusters
then dont worry" assume ther set right ( this is 4 hydrolic lifted valves only)
THINGS TO CONSIDER FIRST
Have you ever worked on cars motors or lawnmowers ?(expeiriance)
Do you have enough Tools to remove the head sometimes special sockets or torx type bolts
LETS SAY DiFFiCulT "
Okay old cheverolets or old ford v-8s that are push rod type engines are the simplest to
to manage The next groupe would be the 4 cylinder imports that either have pushrod
engines or only 1 overhead Cam
following these would be the belt type duel overhead cam with belt type motor and with
adjustable rockers
4 cylinder motors with chain cam drive and and 2 cams also with balancer
After this it would be assumed that motors with duel over head cams with barrel tappets
Then possibly the worst might be the duel overhead cam v-6 with a chain drive
Beware of variable timing cams they can slip as they have 2 gears on one sprocket
above is in referance to order of difficulty "
remove the head from the rest of the engine .so its a lot easier just to chainge the chain befor it slips as you will only need to remove the timeing chain cover
to chainge the stretched timeing chain...and align gear marks i think you use 2 drill bits or bolts to locate the gears as they have holes drilled to stick the bits into as this is the location method for the 2 top cam gears also paint marks can be used it
you are precise enough with the releation of the upper and lower gears
More than likely the timing chain has slipped a few degrees out of sync that would make it have fair compression but still be fireing out of time (maybe even fireing on exhaust stroke) because this is a mechanically distributed engine .
so im going to have to check to see if so were going to have to get a timeing gear set and install The point here is the unburned gas wet plugs are the clue to arise suspician mostly because the engine is fuel injected
next week-end...... thanks
It could have bent some valves". but sometimes it doesent (strange)
thanks for reading and please understand that i hope you can acheive
something better then i have in life"
And please don't just assume I'm just an a-hole venting some anonymous angst. I'm way too old for shenanigans like that. I just want to become the kind of mechanic my antique V8 deserves.
