Variation on the Marshmallow Gun
7,510
11
4
Published
Introduction: Variation on the Marshmallow Gun
About: i love doing random stuff completely out of the ordinary for no reason....
How to make another new variation on the marshmallow gun. The PVC pipe is cheap so it should cost you less than 4 dollars!
Step 1: Materials
Materials:
(all PVC is 1/2 inch thick)
4, 3 inch long pieces of PVC pipe
4, 5 inch long pieces of PVC pipe
3 T joints for the pipe
3 end caps for the pipe
1 45 degree angle joint
Step 2: Put It Together
You can put it together however you want and in what order you want but if you get confused the picture should help a lot.
Step 3: Finish
Now you are done!!!!!!!!!!!!
YAY
to use it put the marshmallow in the hole and blow it through.
Where to do this is designated in the picture
    • Oil Contest
      Oil Contest
    • Stick It! Contest
      Stick It! Contest
    • Casting Contest
      Casting Contest
    4 Comments
    can you use mini-marshmallows or are they regular sized?
    They have to be mini for this design. If you make this with wider PVC pipe, then bigger marshmallows might work, but you would have to blow REALLY hard!!
    very simple thank you
