Introduction: .vbs Timed Pop-up [Code Intended for Notepad.exe]
This Application enables you to open any document and program at a set time. You will be able to set how many minutes until your file is run.
This application will ask you:
1 - What file you would like to use as a Pop-up
2 - How long until Pop-up becomes enabled
3 - And if you are sure if you want to continue.
Answers expected for program:
1 - (Example) File.txt , Log.vbs , Chrome.exe , etc.
2 - Any positive number Example: 1 , 30 , 3 , 16 , 54 , 96 , etc. (A number represents one minute.)
3 - Yes , No
Key words to assist you:
- help
"help" Enables an automated response that states the options listed here and more.
- cancel
"cancel" Exits the application.
*( After code writen save file type as .vbs) [Example: Log.vbs]
*Code intended for Notepad.exe
Step 1: Pop-up Code
Dim w
Dim x
Dim y
Dim z
set oShell = createobject("wscript.shell")
Set sapi = Wscript.CreateObject("SAPI.SpVoice")
x = inputbox("Which file would you like to use as a Pop-up?							Example: File.txt")
if x = "help" then
sapi.speak "Type Cancel to exit."
sapi.speak "Type Help for help."
sapi.speak "For question two answer with a number."
sapi.speak "Each number represents one minute."
sapi.speak "Please re-open this application to try again."
Wscript.Quit 1
else if x = "cancel" then
Wscript.Quit 1
end if
end if
y = inputbox("How long until Pop-up becomes enabled")
if y => 0 then
z = 60 * y
else if y = "cancel" then
Wscript.Quit 1
else if y = "help" then
sapi.speak "Select a number for this question."
sapi.speak "Type yes or no for question 3"
Wscript.Quit 1
else
msgbox ("Character not valid")
Wscript.Quit 1
end if
end if
end if
w = inputbox("Are you sure?")
if w = "yes" then
msgbox("Thank you for using a Code by Allzweck Namen.")
Wscript.sleep (1000*z)
oShell.Run (x)
else if w = "cancel" then
Wscript.Quit 1
else if w = "help" then
sapi.speak "Please type yes or no for this question."
Wscript.Quit 1
else
Wscript.Quit 1
end if
end if
end if
Step 2:
*Help for debugging may be available.
