Very Cheap 1.5 $ Angle Grinder
2,763
29
7
Posted
Introduction: Very Cheap 1.5 $ Angle Grinder
its for those people who don,t have a high budget, and want an emergency angle grinder .
its ready in half an hour or less ( depending upon the type of epoxy you use)
material required -
1x instant glue ( i used feviquick )
1x araldite
1x angle grinder blade
1x hand drill
1x small plastic piece( optional )
Step 1:
procedure -
mix the 2 set epoxy and keep it aside
put some feviquick on the head of the drill( be careful don't let it go in inside the hole )
put the plastic piece on it
let it dry
put some more feviquick on the plastic piece
mount the angle grinder wheel on it top
see that it is calibrated in the center
put the mixed epoxy on top and bottom where the plastic is stuck to the angle grinder blade ,
let it dry
Step 2:
test-
take a metal piece
turn on the drill
it there is lots of sparks it is good
if not , then it is not callibrated well
break it and restart
have fun
Step 3:
AND PLEASE VOTE FOR ME IN THE BUDGET CONTEST and the TOOL CONTEST !!!!
HAVE A NICE DAY !
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    7 Comments
    Hmmm... But before you use it you need to use the right safetywear.
    Be careful. First of all use a guard, because it needs one in the first place, you could make it out of a bottle. Second, if the grinders are set up wrong they are even more prone to breaking so if you have this and it is the slightest bit off it will break. Good concept. Just be careful
    thanks a lot for the advice , i will surly make it :)
    I agree with making a guard. should wear a face shield too. I like it though!
    Construct a blade guard too, lest the tool be part of you.
    It is dangerous..
    I wonder is it safe enough.
