Introduction: Vintage Tilt Piston Compressor to Steam
This is the engine that was converted from an old special tilt piston air compressor. This is the exact same principal from a certain type of "Air Hogs" plane engine. In the opener the engine was running at 35-50 psi and the second start was around 75-80 psi. Top RPMS so far is 1700 at 110 PSI. The timing still needs some work. Solenoid Valves with a Reed Switch and a Magnet are great ways of testing air/steam engines to perfect the timing. A slide valve will eventually be needed as the solenoid valve is rated at 100,000 - 1,000,000 cycles. This engine would wear it out in a day.
mekennedy1313 (author)2012-08-27
And one can find these old motors where?
About This Instructable
2,553views
8favorites
Bio: You may recognize Dan and Denise Rojas from their appearances in various made for tv movies and national commercials. As the hosts of Green Power ... More »
More by GREENPOWERSCIENCE:Drill Glass bottles to make a Water LevelProjection Fresnel Lens Linear to Spot Conversion3D fiber optic art glass springs from a Fresnel Lens
Add instructable to:
