3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
virtual graffiti
Step 7Setting it all up
setting it all up
Download the virtualGraffiti software below. Extract it into your sketchbook directory and then follow these steps!
* power up spray can, check status LED light is flashing.
* turn on computer, plug in spray can receiver,
* setup screen and projector,
* check that spray can receiver status LED is flashing,
* start processing and load the virtualGraffiti program,
* check that you're getting both RX and TX serial indicator LEDs are flashing on the arduino board,
* press both buttons on wiimote,
* do 4 point calibration when prompted (put spray can over each target in turn, then press the nozzle till the writing goes red).
* have fun!
5 comments
Apr 14, 2010. 7:11 AMulfilas says:
 Having trouble with this :( should this be run in processing? If so - do I need to rename this as another file name? I did try - but I get errors. Was it an earlier version of processing than the one currently available.. do I use the withoiut java one?
Feb 14, 2011. 7:59 PMsanspaper says:
rename it to a .pde file.
Apr 14, 2010. 2:50 PMulfilas says:
 okay so I managed to work out ow to extract the file by changing its name from a tmp file to a tar.gz and extracting it using 7-zip !  I now have the file open in processing - I'm getting a thing saying that "package III does not exist. You might be missing a library"
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:matthewvenn
I'm an artist/engineer excited about making cool stuff!
