3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
wall lamp from old computers
Step 5Attach the circuit boards to frame
attach the circuit boards to frame
This step may be time consuming, but you get the hang of it fast.
For a frame I used an old wire shelf (probably from a closet organizer).
First, remove all capacitors from the boards.  Use hands or pliers (beware, pliers can damage the capacitors).
Set the capacitors aside for later use.
Next, cut  pieces of wire ranging anywhere from 5" -15" long.
Connect the circuit boards to the frame.  Mess around with placement first.  I started with large pieces on the outside, smaller boards toward the center.  I recommend using at least three connections on larger boards.
Don't forget to leave an opening in the center for the small light socket.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:jonwald(jon wald)
