3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
waterproof container from little propane cylinder in 10 minutes
I recently thought of this reuse idea after discarding numerous spent propane cylinders. I recycle a lot of metals instead of throwing in the landfill but the recycling plant will not take these for obvious reasons.
The containers are quick and easy to make and offer lots of different uses such as camp stoves, speaker enclosures, storing items, one more thing to put LED's in, etc.......
        Disclaimer!
Make extremely sure propane bottle is completely empty before cutting! Once bottle is empty it still has enough residual to cause a potential explosion hazard. Make sure bottle is at room temp, depress valve to ensure there is no pressure. Then puncture a hole and place bottle as if you were draining liquid out,  the residual will drain because propane is heavier then air.
Step 1Gather tools and materals you will need
First thing is first, you will need these few items:
Small LP bottle with plastic base
File
Abrasive pad
Awl or sharp punch
Hammer
Hacksaw
14 comments
May 13, 2011. 5:32 AMandygreene says:
You can buy an adapter to refill these. You can refill them a few times before the valve gaskets / o rings begin to leak. That way, you can get a few extra uses out of these before trashing them or re-purposing them.
You fill them from a 20# or larger tank. I'm sure there will be warnings about safety concerns, but when refilling in this capacity, your larger tank won't refill these to the same pressurization as the original 1 lb tank held, so you are probably only going to encounter a leaky valve after filling as the worst case. If you leave the tank screwed onto an appliance with a valve, you can shut off the leak.
Jan 7, 2011. 8:31 PMdigitalbrad says:
I believe there is a schrader valve in the top where the propane comes out. You should be able to remove it with a valve core tool.
you know when you fill your bike tire with to much air, and you press that little metal piece under the cap. that is a schrader valve. and yes as Vadim said, a common way of making sure all the gas is out is by filling the container with water, otherwise big boom could be big ouch.
Feb 24, 2011. 2:36 PMsabr686 says:
Please explain the safe procedure you use to fill the propane container with water. I'm sure I'm not the only one who would like to know. Thanks!
Mar 20, 2011. 1:13 AMdigitalbrad says:
well with one of these propane tanks, you would remove the schrader valve with a schrader valve tool and then just adding water through where you removed the valve.
Mar 20, 2011. 2:56 PMsabr686 says:
Thanks! Off to get a shrader valve tool.
Jan 8, 2011. 8:31 PMl8nite says:
maybe more water resistent than waterproof ( I wouldnt want to drop it in the pool with my camera inside) but a nice container
Jan 8, 2011. 9:11 AMrimar2000 says:
Another.
Jan 8, 2011. 11:25 AMrimar2000 says:
I used a free image editor, did "paste as new image", then "+gamma factor" three times until the result was satisfying, and then "save as". It is so easy and so useful!
Jan 8, 2011. 9:08 AMrimar2000 says:
If you correct the gamma factor (+), you can see more details in that dark image.
Jan 8, 2011. 6:02 AMiPodGuy says:
Cool, but... what is that you're using as a lid?
Jan 8, 2011. 6:24 AMKiteman says:
It's the plastic base - see step 2.
Jan 7, 2011. 5:47 PMVadimS says:
It's common practice to fill the bottle with water to garenty there is no gas left.
But nice.
Jan 7, 2011. 5:20 PMDr. Pepper says:
Very well done!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:transam_dream
