Step 5Finishing the build + more paint
alright so now the inside is looking tight and packed. just have to take care of the back panel and some paint:
- the center hole in the back panel is the same size as the power plug connector. it is simple to screw fasten the bolt in place as in the picture below. in the end I had to dremel the opening a bit for it to fit comfortably.
- next position the back panel and close the case, then secure with 3 screws. I had some from an old project that were perfect for this.
- now the construction is finished and its time for more paint! I covered the back, front and the airflow holes in the sides with newspaper and tape then applied a couple of coats of satin spray paint for plastics.
now with everything in place its time to install some software.
Add Comment
