iImage Information
This is a wind generator that I built with 2 Ametek 30 Motors. It is still in the experimental stage, with 3 blades on 1 and 4 0n the other. The 4 blade prop has a saw blade for a hub (Not recomended) . I will be using the 4 blade setup on the ones I am building now, along with an aluminum hub. I am working on a new set of blades now.
Step 1
iImage Information
I started with two amtek 30 motors, inside 4 inch pvc. Held on by 2 ss hose clamps. I will put on 1 more later. I made the hub out of 3/16 aluminum and a 5/8 motor arbor from Amazon.com I replaced the screws with allen head set screws and got heavy duty half inch washers. To hold the wire in the tube I drilled a slightly smaller hole in a piece of real hard wood and 2 holes for 1/4 bolts then cut it in half. I also cut some doubler plates out of pvc for the blades. I used heavy duty extension cord inside the pipe tower.
I built one of these and it works great. I bought most of the parts on ebay.
The criticism I have with the design is the blades. I live in New York and we can get som serious wind in excess of 35 mph. The first day the wind gust went over 35 mph, the PVC blades snapped and crumbled into pieces. What a disaster!
I wound up replacing the blades with some aluminum blades I found online at windynation:
http://www.windynation.com/shop/index.php?act=viewProd&productId=14
So far so good and it has been 9 months. We have had a couple of days with 55 mph wind gusts.
I would also recommend getting a slip ring if you live in an area with swirling wind like me. It will eliminate the tangling of your wires which run down your tower. Thanks for the article. I thought it was great.
http://www.tlgwindpower.com/Ametek30data.htm
I believe this is the motor used here (if wrong, please correct me).
I'm doing the same thing you are in my garage.
Right now I power my lighting and hope to improve to power tools (actually charging my Dewalt tools as well).
We should talk!!
