3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
wiper glove
Step 7Final thoughts
I had originally designed this to be a slide using the metal shanks from the blade body, that way the blades could be interchangeable. However it was too difficult to implement for such an easy project and sewing it directly on the glove is idiot-proof.
Also after a few days riding I thought of an alternate position for the blade might be under the meaty part of the thumb. Which would still allow you to wipe your visor and keep it out of the way of any bike controls.
I'd be interested to see any modifications of this cheap and easy build, such as if anyone finds a way to make the blades replaceable and fix it to the glove without scratching the visor. Good luck, and please post your results, its a fun build!
6 comments
Jun 29, 2008. 2:33 PMscwirral says:
You can buy something like this that slips over the first finger of your gloved hand which has two plus points. One that you can swap it if you have more than one pair of gloves, and that if the rubber needs replacing you can do this easily. I intend to have a go at a wiper blade visor cleaning solution along these lines, although I think mine will be bonded using epoxy resin.... my sowing sucks!
May 19, 2009. 5:57 AMharleyboybob says:
please where can you buy or what is the name of the product
Mar 17, 2010. 1:44 PMradiograf says:
Here in the UK they are made by a company called Bob Heath Visors, and are known as the Vee Wipe.
Aug 15, 2008. 4:12 PMI_am_Canadian says:
*sewing. sowing is somthing very different.
Jan 30, 2010. 12:34 PMsideshow72 says:
hey man as far as attaching new blades or just removing them when they aren't necessary, get the velcro that has adhesive backing and then sew one piece to the glove and sticky the other piece to the blade portion. im not sure how well the velcro would stick the rubber, but its worth a shot.
Jan 25, 2010. 6:32 AMRennis says:
I have a pair of touring gloves for riding and they have a wipe blade built into the back of the thumb...
I think this give you much more conrtol when wiping your visor/goggles/etc...
Jan 22, 2009. 11:59 AMGoodluck says:
Garbage cans outside of an auto-parts store on a rainy day would be a treasure trove of old wiper blades. One might want to look carefully before plucking as they are probably a treasure trove of nasty stuff as well.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
763
Author:mikeasaurus(michaelsaurus.com)
I'm the Play Editor here at Instructables! I like mixing old ideas with new and reusing things not for their intended purpose; the results are sometimes messy but always fun. I also write the thrift-...
more »
