divide them there will be one loop in the middle and in each side the same number of loops take each faced two and twist them together as seen in the ...
wrap numbers of branches as u like i wrap three pink and one balk wrap them tightly and wrap a wire around the all evenly like a coil to hide the ste...
to finish the trunk i wrapped cotton around the stem then alum foil finally i wrap the wire around them all evenly and make 3 roots at the end to be a...
i just have a question, i love this project and can definitely see myself making one, but what gauge wire do you use? thanks for the instructable though!
hi i am so glad that u like my tree thanks lots for passing by i used 4 gouge wire in Egypt my home we call it 0.4 it is really good to pass through the bead twice and soft to be wrapped easily
your welcome anytime i used a larger kind you can use seed beads but you should use a thinner wire to secure the passing of wire twice in the bead about 0.2
thanks lots for passing by i attach wire to each root end and tie the wires around a rock them make a base with gypsum and glue or i put the tree in a dish or a bowel or vase and put gypsum paste around the roots
Isn't Gypsum "Plaster of Paris?" I used masking tape to make the roots stick to the bottom of a flower pot, a small can, etc. Then I filled this with stones held together with white glue Invisible when dry! About 2 days!. Works for me!! But HOW did you get the roots to stick around a ROCK???
thanks for sharing I went to the store and got all the stuf fneeded and imideately got down to making the tree it took me about 4 or 5 hrs the first time . i mounted it on a rock and gifted it to my mom. it has a special place in her living room. the second one i made using red beads and a golden wire mounted it on a lava stone and am very happy with the results. thanks again
No i did not stick it or screw it on i made two roots longer than the rest and then used these to hold the tree in place by twisting them underneath the stone the other roots were placed around the rock to give support and to make it look nice. have still no been able to upload the photos of the same
This is quite beautiful! I am glad you were able to work out how to create an Instructable with your pictures. I agree with the previous comment, you really ought to enter this in the DIY Wedding contest!
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
about 0.2
or
i used stones or beads to make it looks like
a ground around the tree
say hi to your mom
hope to see your projects
thanks for passing by
i am so glad that you make these trees
from my tutorials
god bless you sweetie
god bless u
awaiting to see your tree
thanks sweetie
i will try to make video
which step is not clear???
i can clarify anything u want
thanks again
it takes no time once u know the steps
your welcome
