Transfer Power Without Wires
1,086
19
Posted
Introduction: Transfer Power Without Wires
hey there! this instructable is about how to make a circuit that can transfer power without wires.
THIS CAN BE USED IN HALLOWEEN PROPS.
Step 1: Materials You Need-
electronic components needed -
transistor 2n2222
26 gauge copper wire
9v battery
100 ohm resistor
9v battery cap
and wires.
tools and equipment needed -
soldering iron
soldering wire
nipper
wet sponge
multimeter
flux
etc
extra equipment needed -
solder fume extractor
a cylendrical object to make the coils (i have used a deo can)
Step 2: Circuit Diagram-
THIS IS THE CIRCUIT DIAGRAM
Step 3: Constructing the Secondary Coil and the Led.
Take your deo-can or any cylindrical object and WIND 10 TURNS OF COPPER WIRE on it LEAVING 3 INCHES FROM STARTING.
TO MAKE THE SECONDARY COIL WHICH WILL POWER THE LED.
Step 4: Now Constructing the Primary Coil.
TO MAKE THE PRIMARY COIL -
● WIND 10 TURNS OF WIRE ON THE CYLENDRICAL OBJECT.
●THEN MAKE A TWIST LOOP (IN THE IMAGE)
●AGAIN WIND 10 TURNS OF WIRE OVER THE WINDING.
YOU MUST BE LEFT WITH 3 WIRES.
Step 5: Wiring the Transistor to the Coil
wiring the transistor-(2N2222)
●TAKE YOUR '3-WIRED' COIL AND SOLDER THE LEFT-MOST WIRE TO THE 'COLLECTOR' PIN OF THE TRANSISTOR.
●NOW, SOLDER THE 'EMMITER' PIN OF THE TRANSISTOR TO THE NEGATIVE TERMIMAL OF THE BATTERY CAP.
● SOLDER THE 1k ohm RESISTOR TO THE POSSITIVE TERMINAL OF THE BATTERY.
●SOLDER THE OTHER PIN OF THE 1k ohm RESISTOR TO THE WIRE OF 'TWIST LOOP'.
●SOLDER THE 'BASE' PIN OF THE TRANSISTOR TO THE RIGHT-MOST PIN OF THE COIL.
Step 6: FINAL TOUCHES
now once everything is done hot glue whole circuit to male it WATER-PROOF.
Power it, amd make sure you DON'T EXEED 9 VOLTS.
THIS WILL WORK THROUGH A DISTANCE OF 6 CMS.
THANKS FOR WATCHING, PLEASE LIKE IT.
HAVE A NICE DAY! :-)
  • Epilog Challenge 9
    Epilog Challenge 9
  • Sew Warm Contest 2018
  • Gluten Free Challenge
