Overview:
this is a slide show clicker i whacked together for an English assignment a few years ago. It is basically a simple wireless left mouse click (for flicking through PowerPoint slides during an essay).
Story:
well i was looking for ways of avoiding doing my assignment (as i am a professional procrastinator) and i figured a usb slide show clicker would be perfect.
The outlines for the clicker are:
+ storage of files.
+ decent range from computer
+ cheap and simple
+ use readily available items
Stuff you will need:
+ an old (working) usb mouse
+ some form of wireless device eg:
+ gate opener controll systems (best)
+ old remote control car/things
+ any wireless device that can run a relay
+ two way usb devider (optional)
+ usb storage device (optional)
+ various materials (wood, plastic,metal ect)
+ plugs switches screws ect
*my camera was broken for most of the building process, thus there aren't many pictures of construction.
Remove these ads by
Signing UpStep 1Planning
I wanted to create a device I could use as s simple wireless left mouse click for use in slideshows ect. I included. I included a usb divider so that you are capable of still using the USB port in use for the clicker, as well as giving the device internal storage.
how it works
since (as i said before) i don't have many construction photos, i have drawn a diagram of how it works. it starts by dividing the single USB (from the computer) into 3 separate ones:
+mouse input
+storage device
+external USB (used for other stuff you may want to plug in)
the mouse input simply takes connections from the computer mouse left click and puts them through a relay. The relay is then controlled by a receiver of some sort. In my case it was an old gate opener setup, as it already has a relay it is excellent for the job, but you can use just about anything that could power a relay, such as the drive motor output form an old RC car.
the storage device is a storage USB plugged into one of the inputs of the USB divider.
the external USB can be used for alternate storage devices, or in cases where a computer may require use of all USB ports you can continue using the device that was previously using the port.
design
well this is entirely up to you, and i recommend you experiment with the aesthetics of your device, its no fun to just travel to your local electronics shop and buy an ugly black box, make something different.
comments
Add Comment
Add Comment
