Step 3Chop bike 2
On most bikes the stem (the thing connecting the steering tube with the handlebar) is aluminum, so you can't easily weld it. The stem can't be completely removed because it usually is needed to hold the steering assembly together. So we need to find an exposed area of steel that we can weld to. If the end of the steering tube is accessible that is a good spot, in that case just cut off the handlebar and excess stem. If you can't weld to the steering tube then you can weld to a steel handlebar. Cut the handlebar very short (maybe 3" long) to provide just enough space to weld to.
Add Comment
