This is a guide on how to build a woodstove from scrap.
you can also read this in dutch:
http://www.engelweb.nl/houtkacheltje
Step 1: Get a metal container.
First you need to pop down yer local chippy + get an empty oildrum + a pea fritter!
height about 50cm
diameter about 30 cm
depending on how big space you want to heat.
I have also tried various metal rubish-bins.
it doesn't matter if the metal is thin. that way it heats up the space much faster.
don't use anything aluminium. it will catch fire when tempreture gets high enough for spontanious combustion, melting or realy aggressive burning with hot sparks flying about.
gmoon says: Nov 13, 2007. 5:50 AM
Nice drawings--wish they were larger! Should galvanized metal (zinc content) be avoided?
fretted in reply to gmoonJan 27, 2011. 2:55 PM
Tes zinc should be Avoided not only the smell is bad but the fumes are Toxic
awang8 in reply to gmoonJun 13, 2009. 3:06 AM
I don't think you'll find zinc in oil drums...
_soapy_ in reply to gmoonNov 23, 2008. 6:55 AM
Avoid zinc, it will give you the headache of a lifetime. Burn it off first by putting the drum in a large bonfire. Light and leave it until the next day. (This also works for paint and oil on drums) Don't breathe the smoke!
carsten888 (author) in reply to gmoonNov 14, 2007. 1:56 AM
thanks. Believe it or not, I just found the drawings on a gathering in the UK about 10 years ago! It says a anti-copyright notice so i multiplied some for other travellers to use. Later I took this info with me to Holland and some more of these burners where made. Anyways, the drawings just happen to be very small, sorry, can't help it.
LinuxH4x0r in reply to gmoonNov 13, 2007. 3:51 PM
STAY AWAY FROM ZINC it gives off nasty fumes when it burns.
ToyMaker says: Nov 13, 2007. 6:20 AM
in step 1: "don't use anything aluminium. it will catch fire when tempreture gets high enough for spontanious combustion" What? Did you mean melt? Didn't read past that.
stevejohnson007 in reply to ToyMakerOct 13, 2008. 11:53 PM
Metal burns friend. fireworks and flairs are magnesium, and if you wanna make something really impressive, mix a little alluminum dust and rust dust... you get thermite. actually, dont it spatters, and cant be put out with water.
carsten888 (author) in reply to ToyMakerNov 14, 2007. 2:00 AM
fortunately I have never experienced this myself, but I have heard plenty of stories of people who have used aluminium (like the old milk-containers) for a burner or chimney with it either melt or starting to burn in a very agressive sparkly way. I spoke to someone who once had a burner from a aluminium milk-container and the thing just started to frow sparks around, he had to flee out of his bender and 10 minutes later all was ashes.
jtobako in reply to ToyMakerNov 13, 2007. 7:39 AM
May be confusing aluminum with magnesium (or zinc). Could use some explanation of why some things were done the way they were-like no ash dump, if the clay needs sand or hay in it so it doesn't form steam pockets, could you use sand instead, some indication of scale would be nice, how the bean cans might be put together, why upright and not horizontal, something about how to get the flue outside... Good HIDI (How I Did It), nice humor.
carsten888 (author) in reply to jtobakoNov 14, 2007. 2:07 AM
o (forgot). about the clay, I never bothered with mixing or anything, just dig down and used whatever claylike substance was about. Think globally, act locally. whatever was easyest to obtain. I'm sure some scientist might be able to tell which sort of clay would work best and what mixtures and such. But this is travellers' science. Keeping it simple, yet effective at no cost.
lukeyj15 in reply to carsten888Mar 21, 2010. 7:40 AM
 Don't use shale, it can explode.
carsten888 (author) in reply to jtobakoNov 14, 2007. 2:04 AM
feel free to make a ash dump. I used a lot of clay to retain the heat, and a ash-drawer was difficult to make in combination with the clay. But I found scooping the ashes out with an old soupspoon every other day was no hassle at all. scale: height around 50 cm diameter: about 30cm but sized depends much on how big a space you want to heat (and how much wood you want to burn ;-)#
Marojale in reply to jtobakoNov 13, 2007. 7:52 AM
Try burning a pop can with a blow torch. You'll see the aluminum (aka aluminium) get white hot and start combusting. It looks kind of like magnesium burning but it's not self sustaining at ambient temperatures (i.e. once your turn off the heat, it will stop quickly). Where would you get a magnesium container large enough for this anyways?
BarefootRandom says: Sep 14, 2008. 2:11 AM
If you are a competant welder, old gas cylinders make good wood stoves and last longer than thin steel. However it is essential to remove all traces of gas before welding and cutting begins. Make sure the bottle is empty, then you MUST remove the outlet valve, once remove tip the bottle upside down to let out any gas. Then fill the bottle with water for a few hours JUST TO MAKE SURE ALL GAS IS REMOVED. OH AND NO SMOKING WHILST DOING THIS.
carsten888 (author) in reply to BarefootRandomSep 14, 2008. 8:47 AM
I tried that too (got someone else to do the welding for me), but found that If the metal is thicker it takes a long time for the burner to get hot enough to heat the place. During this time most of the heat goes out the chimney, so you're freezing for another hour waisting wood and then it gets realy-realy hot and you have to shut the air intake or so else it gets too hot. So for bender-dwellers and yurt-inhabitants: if you want instant heat and not waste wood waiting for the burner to get heated up, go for the thinner metal. Thin metal won't last as long as the ticker stuff, true.
BarefootRandom in reply to carsten888Sep 14, 2008. 10:46 AM
Your right about thinner metal heating up quicker, and i guess when it rots, its cheap enough to make another one.
abadfart says: Jul 28, 2008. 12:00 AM
nice ill put this in my yurt
chickenliver123 says: Dec 8, 2007. 8:34 PM
cool, i will try this!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
