Wooden Cross Bow
16,985
5
40
Posted in PlayOffbeat
Introduction: Wooden Cross Bow
About: im very interested in doind stuff with ordinary house stuff and turning them into an invention
a wooden cross bow that fires wooden kebab sticks 10m there is no trigger
u use yuor finger to hold it in place
i finisjed mine off with some duck tape over it to make it more confortable
Step 1: Equipment and Meterials
for this you will need
wood planks
sowing elastic
nail gun
staple gun
saw
ruler
pen or pencil
wooden kebab sticks
measuring tape
wood glue
this is about all you need to make it
i did it in a week cause i did a bit here and there every day
Step 2: Measuring and Cutting
main body: 19 inches long 2 inches wide x2
arms: 9 inches long 1 1/2 inches wide x2
arms 2: 4 inches long by 1 inch wide x2
top bit: 2 inches long by 2 cm wide
variables
ammo bit
2 pieces 9 inchres long by 1 cm wide
1 piece 1 1/2 inches wide and 9 inches long
cut these out then youll have all you need to make the croosbow
Step 3: Assembling the Crossbow
main body: take the 2 cut out body pieces and put wood glue on 1 side of 1 piece the put the glued faceon top of the other piece the use nail gun in four corners and thruogh the middle
the tape over it the put it aside to dry
arms: take 1 big arm and 1 small then put the small one on top of the big one at the edge and slant it so that the 1 conner of each is nearly touching and you have a slant L SHAPE the nail gun it and tape it then do the same for the remaining arms
cross bow: take 1 arm and put the untouching end when the corners are touching do same with other arm and the gap should form a v with 1 cm space for the ammo to go through
top bit: take that small piece and place it on top of the arms so that if you looked at it as if you were aiming there is a hole ( this small piece is there to keep the skewers in place so that when you fire they wont flip in air)
and nail gun it into place
ammo holster: turn the finished crossbow over and take the 2 strips of wood and place them starting from the start of the bow and nail them then the last remaining piece goes on top and nail it as weel
then finish off by doing any taping you havent done
string: get the sowing elastic and get a piece about 6 inches long as its original lengh ( you can vary with the size ) and take 1 end about 1 cm away and stretch it along the arm joint sideways and staple gun it the do same with other end and you now have a crossbow
i got my skewers from the tesc extra near denny and the elastic
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    40 Comments
     I made a slightly shorter (by 2 inches) crossbow made of paper which has the exact same range but is prone to unspectacular failure.
    I have made this exact thing with my cousin. we where just messing around in a wood working shop and this is what we came up with. I think the only difference is that we used clothes pins as triggers.
    I've made several toy crossbows using PVC pipes. Today I made one out of a 2x3" piece of pine that is approximately 3' long it has a leaf spring from a trailor for a prod and the string is the metal wires that are used to hold your bicycle tire on the rim. when I get a cam worth using I'll post some pics and instructions for a good trigger. May even post a vid of it shooting through a garbage can or something. have fun guys.
    1.first is the one with a wooden frame and an rubber band to create the power
    2.this one has also a wooden frame but a normal string and the PVC pipe to create the power.
    3. this is my simple pen cross-bow, not really effective but, 15 meters he flies surely.
    I hope you like it!
    hey could u atleast tell me wat u used for the trigger
    a little hooked like iron slat.
    nnnot really, it is just a piece of iron which we hooked with a saw.
    can u post the one in the second pic it looks tight
    maybe.... I`m sorry I can`t tell you now maybe later
    ok.. soo wat duz it fire real bolts?
    check out my corssbow instructible
    that is awsome home digidy dog
    Hey could have been neater, but does anyone know waht type of string would be best for a similar project. Also the 2nd crossbow made by oldschoolstructure is supasweet, i would love an .
    check out my five minute crossbow...its awesome... you might be able to replace glue w/ gum or sumthin...and make it at skewl! dont get caught tho!!!
