iImage Information
I have always loved wooden gear clocks. So for my birthday my wife gave me a Dremel and a copy of Scroll Saw Magazine that had a pattern for a wooden gear clock. This is my entry for the clock contest and 4th Epilog Challenge, it is also my first Instructable. So fair warned. I have had thoughts on making gear clocks to sell. If I had a Zing laser cutter then cutting out the gears would be much more precise and need much less sanding and fine tuning.
Step 1Get a pattern
iImage Information
My pattern came from Scroll saw magazine spring 2011 Issue 42. You don't have to get this one It just had a good pattern and instructions.
You should explain a least how to properly cut the gears...
Poor instructable (but nice job ;) )
juanvi, You can ether use a Dremel (harder) or a scroll saw. I used contact spray glue to glue down the template onto the wood then cut around the lines, then lots and lots and lots of sanding to make the gears mesh correctly allowing them to turn without binding.
im in high school and i was looking or an easier way, you see i have all year to biuld it, but 618 teeth is alot! (90,8,64,12,16,40,10,48,(8,60 x5))
band-saw get them down to about 1/32" but then im on my own filing/sanding
i use a scroll saw but it slow work very slow...... jigsaw chips the Baltic birch to back
so i found a strip sand on the internet would work better i dont have this tool
i have all the tools i method at my disposal except a strip sander so please is there a power tool that will sand this for me,,, that i can buy under $100?
Is this what you mean by a strip sander?
http://www.harborfreight.com/air-belt-sander-97055.html
We've posted a video of the clock in motion on our magazine's website
http://www.scrollsawer.com/videos/building-a-working-wooden-gear-clock.html
The designer, Clayton Boyer, also has several other gear clock plans available:
http://lisaboyer.com/Claytonsite/Claytonsite1.htm
Like the magazine title says, the project was designed to be cut on a scroll saw; I'm impressed that you cut it accurately enough with a Dremel.
Please feel free to drop me a line if you have any questions!
Best Regards,
Bob Duncan
Technical Editor
Scroll Saw Woodworking & Crafts
http://woodgears.ca/gear/
No affiliation, just a fan of this engineer's woodworking site.
http://www.foxchapelpublishing.com/product_p/ssw42.htm
I wonder how hard it would be to laser-cut the pieces. I'm thinking about the thicknesses involved.
I can probably work out the gears myself in CAD but that pendulum mechanism I'm not so comfortable with
If I placed it outside near the doghouse I could reset it again each morning when I feed the pooch...
