Introduction: Woodland Bow
bow from your garden easy and no cost to make :D
I AM NOT RESPONSIBLE FOR ANY DAMAGE OR HARM TO ANIMALS OTHERS OR YOURSELF. THIS IS USED BY YOUR OWN OR PARENTS SUPERVISION. BY MAKING THIS ITEM YOU AGREE THAT YOU CANNOT SUE FOR MAKING THIS ITEM AFTER READING THIS TEXT IN CAPITAL LETTERS!!!
Step 1: The Matierials!!!
All you need is a big sharp knife.
A ball of string .
And mans best friend a stick!!
Step 2: The Stick!!!
Mostly you need a straight bendy and thickish stick.
The one i used which grows in your garden is a privet stick,
they are bendy and strong and well the good properties for a bow.
make sure it is straight !
try to use a privet stick if u can.
Step 3: The Notches of Doom!!!
For the notches you use your big knife and cut a 90degree line into it ,then slope it off up out the stick.
NOT INTO THE STICK!!
Step 4: The String!!!
All you need is nomral houshold string that you can get from ur cupboard in ur kitchen or garage or the shop for 90p BUT NO!!! KNITTING STRING BECAUSE ITS CRAP.
Measure the string to 4.5ft and tie loops at the end of it a normal loop would be fine but if you know the lassooo not it would be better as it tightens when pulled on and loosens when unpulled
This will be perfect for your 5 ft stick
Step 5: The Putting Toghetherness!!!
Right all you need to do is put one end of the loops on one of the notches and turn it upside down
and put the other one on.
If the string is too loose or too tight undo one end and make it suitable for ur stick
Step 6: Arrows!!!
All you need to do is get a straight sitck about shoulder to hand length and sharpen one end and cut the other one so it is flat and place on your bow and fire
Step 7: Finished!
Even though you have a bow it will only fire at the max a couple of yards like tops 50 yards
you can add flights if wanted or weights at the front to make it more stable and arch more easilly
but remeber safety first and have a good time
please tell me and others what you have done to make it more better and cooler.
