Working K-nex Grenade With Pin!
Published
Introduction: Working K-nex Grenade With Pin!
About: I call myself the cameraman because cameras are my LIFE (so is k'nex and computer stuff). I have so many ideas, but just so much more stuff I need to do! so I can't post much. sorry about that. Models I am ...
this thing is double the size of others, so more shrapnel will fly out. the only problem is when building you have to be careful or the grenade will fall apart. if this is similar to someone elses I am sorry.
Step 1: Get Your Pieces!
in this photo I have only 1 rubber band. you need 2 instead of 1. you need:
8 green connectors
3 snowflake connectors
24 yellow half moon connectors
8 red connectors
2 gray single slot connectors
1 gray rod
4 gray spacers
4 blue spacers
2 rubber bands
Step 2: The Bottom
this is the bottom of the grenade. you need:
8 red connectors
1 snowflake connector
Step 3: The Bottom Body
this is the bottom body of the grenade. you need:
8 yellow half moon connectors
Step 4: Body Connecter
this here piece connects the bodies of the grenade. you need:
8 yellow half moon connectors (I here used gray)
Step 5: Upper Body
this is the upper part of the body of the grenade. you need:
Step 6: Top
this is the top part of the grenade. you need:
8 green connectors
Step 7: Pin
this is the pin that allows the explosion by this grenade. you need:
1 gray rod
4 gray spacers
4 blue spacers
Step 8: Add Rubber Bands
BE CAREFUL WHILE DOING THIS STEP! A SLIGHT MISTAKE CAN HAVE EXPLOSIVE RESULTS!
put the rubber bands so a large detonation is made. you need:
2 rubber bands
Step 9: YOUR DONE!!!!!
thank you for making my instructible PLEASE SUBSCRIBE!!!!!
    • Slow Cooker Challenge
    • Flowers Challenge
      Flowers Challenge
    • Microcontroller Contest
    I am going to eventually make a grenade launcher that shoots this grenade
