n: how to make a multi-layered acrylic and LED sculpture with variable lighting levels
 by slight
Featured
Here you can find out how to make you very own n as made for the exhibition www.laplandscape.co.uk curated by art/design group Lapland.
More images can be seen at flickr
This exhibition runs from Wednesday 26 November - Friday 12 December 2008 inclusive, and had a private view on Tuesday 25 November. Each participant has been asked to make a letter each of the 'laplandscape' portion of the web address. On the website each letter will link to related web contributions from each participant. This instructable is our web exhibit for this exhibition.
This n is an art work and experimental and these instructions should be treated as such!
The n takes the form of 5 layers of laser cut acrylic, 3 of which have LEDs in them. The front panel has the outline of a letter n etched in it. 3 knobs control the LEDs and fade them between the ones inside and outside the outline of the n being on, on each layer.
There are no doubt simpler ways if wiring up the LEDs to do the same thing but, as all the exposed components etc are a big part of the aesthetic, we decided to do it this way.
Enjoy!
Step 1: Gathering parts
Electronics
150 x LED's - Yellow
150 x carbon film resistors - 0.5W 68ohm 5%
6 x transistors
3 x 22k pots
3 x knobs
1 x arduino decimila
4 x stripboard
pin strip
Stuff
5 x 3mm acrylic sheet 610mm x 610mm
small white cable ties
4 x 400mm M10 stud
38 x M10 nuts
4 x M10 dome nuts
Power
1 x regulated power supplies 4.5volts 1400ma
1 x regulated power supplies 7.5 volts
Consumables
solder
super glue
araldite
slight (author) says: Jul 14, 2012. 6:58 AM
We're about to pull apart this piece and reconfigure it to be a LED 'fire' for use in an empty fireplace.
We'll post an instructable as soon as we have finished!
joerice01 says: Jun 1, 2011. 7:22 PM
Video?
farzadbayan in reply to joerice01Sep 25, 2011. 4:02 AM
Agree, it will good with a video.
gaitskell says: Nov 29, 2010. 7:48 AM
If one doesn't have access to a laser cutter, can one get reasonable quality holes using conventional drill press/drill, or will this spoil the overall effect?
QuackMasterDan says: Nov 28, 2010. 10:14 AM
Superb instructable, especially for your first one! Crisp hi-res images, detailed explanations, clean code, you did a bang up job. Keep up the good work, I'm sure any future guides you create will be up to the same standard of quality.
Very pretty too =]
ziminov says: Nov 24, 2010. 6:39 AM
Wow. So easy!
alinke says: Nov 24, 2010. 6:06 AM
wow so cool, thanks for sharing and well documented. Would be nice to also to see a video of the n.
polettdaniel says: Nov 24, 2010. 2:32 AM
Wow, you're great! Congrats!
ongara_01 says: Nov 24, 2010. 12:37 AM
OOLAL LA....cool
canida says: Nov 23, 2010. 3:06 PM
Ooh, pretty! Nice work, well documented!
Ngendrer says: Jul 20, 2010. 10:03 PM
yup that's art keep it up....
arankamonchan says: Oct 20, 2009. 8:42 AM
ART~
me says: Jun 6, 2009. 9:41 AM
woow that looks like a lot of work, nice results though
snowpenguin says: Apr 29, 2009. 2:41 PM
Cool
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
