Introduction: X8 Slide Action Handgun/sidearm
I believe that this is the first ever slide action handgun to feature a magazine that has been posted on this site. Slide action, true trigger, 7 shot bottom loading magazine capable of rapid fire. the range is anywhere from 20 to 60ft depending on how many rubber bands you use and what type of firing rod you use.
Step 1: Make the Barrel
this is the barrel
Step 2: The Magazine
1. make these
2. connect them like so
3. do this with them, make sure it clicks into place
Step 3: Make the 2nd and Upper Part of the Barrel
make this
the decapitated peices are not required but highly recommended if you dont want your gun to jam, they can be replaced by tan clips
Step 4: The Trigger
1. make these
2. connect like so
Step 5: The Handle
1. make this
2. spread the red connectors out (it helps with connecting them)
3. connect them
Step 6: Connecting Everything and Add Ons
1. this is what you should have so far
2. connect the upper part of the barrel
3. connect the two parts to the magazine
4. make sure it looks like this and the white rods go through
5. add the trigger
6. add the trigger
7. add the handle
8. add 4 black y connectors to the front and add 4 green connectors to the sides of the white connectors like so
9. add 4 orange connectors to the front and back, it should look like this
YAY YOUR DONE WITH THE FIRST PART :D:D:D:D
Step 7: Making the Slide
1. make this
2. make these (the purple one is just the same as the gray one) also one has 3 connectors and one has 4
3. attach them on and add one extra red connector on the side with 4. the side with 4 should be slightly moved back
4. add more red connectors until it looks like this
5. now build this
6. attach that onto the end of the slide
7. add this gray connector
8 add 2 gray rods and thread them through the gray connectors at the side
9. attach the slide to the gun
ok your done with part 2 what do you want a cookie?
Step 8: Firing Pin
very simple, two pieces and some tape
1. firing pin
2. slide firing pin through the slide
3. slide firing pin through barrel
Step 9: Adding Rubber Bands
1. add rubber bands to trigger, do the same on both sides
2. add rubber band to make magazine work
3. connect it to other side
4 add rubber bands to firing pin
Step 10: Loading/firing
1. add in white rods
2. put rubber band through like so
3. slide the slide back
after you slide it back, move it back into place or else it will not work, then just pull the trigger.
you have made this gun, yay cheer woot, now go get yourself a dam cookie
