3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
xBox 360 Wireless / Wired / Cordless Headset c/w Microphone
This the first thing I've ever shared online (please bear this in mind when it comes to the comments, although all comments, good or bad are welcome).
In this Instructable I'll show you how to mod an old pair of headphones to make an xBox 360 Headset. There are 2 options here, wired or wireless, the choice is yours.
Heres what you'll need -
1x Headphones, wired (with inline volume control if possible) or wireless / cordless
1x Basic 360 headset (available on eBay for less than ý5)
1x Small Screw (approx. 5/6mm long)
Insulating Tape or Heat Shrink (black if possible)
Soldering Iron
Solder
Drill & Drill Bits
Small +head Screw Driver
Step 1Dismantling The Headset / Headphones
This is quite easily done. If you look carefully at the back of the earpiece of the original xBox headset you will see small tabs which can be pressed with a small screwdriver to seperate the earpiece from the headset. Next take your soldering iron and seperate the cable from the controller from the earpiece and microphone (take note of which wire goes where). Then remove the small screw which secures the micrphone boom to the headset.
Next dismantle one of the earcups of your headphones. Be careful doing this as different headphones seperate in different ways. Some just pull again, others twist. I ended up breaking the clips which hold mine together so ened up having to glue it back on.
11 comments
Oct 29, 2009. 3:27 PMraymond25 says:
 Yo anybody know where I can get some free xbox 360 tools here in saskatchewan,canada !
Oct 29, 2009. 3:24 PMraymond25 says:
 Why didn't xbox add the red white and blue cables to the system!  Morons.
My advice if you can't figure out how to get feed from a regular mic (not the xbox kind than maybe soldier some components or just buy components that hook into one another !~ Somethings gotta give ! :)
You also should listen to the song Swing ! It is Sweet !
Jul 28, 2009. 9:19 PMMspuck15 says:
is there any way to transmit the sound of the tv to the headset like the Turtle Beach headsets. I have no idea if its possible or not though but i was just wondering.
Oct 7, 2009. 4:21 PMBorisTheSpider says:
Hey, I've been thinking of doing this for some time myself. One way to get the voice through both sides with this setup is to change the voice option in the xbox 360 menu.
There's an option in there to choose whether you want voice through the headset or the speakers. Just switch that to speakers and you should be good to go. Hope that helps.
Jul 30, 2009. 5:50 AMMspuck15 says:
i connected the just plain bronze wire to the same wire from the mic and the same with the pink one but there are still the blue and black wires and im not sure where to solder those
Jul 31, 2009. 11:10 AMMspuck15 says:
sorry i typed the wrong email before its mm.sull19@gmail.com thanks
Jul 15, 2009. 8:35 PMPSPerson says:
i like it... its like a DIY version of those $40 ultra gamer headsets that plug into your TV and your xbox controller.
May 10, 2009. 1:46 AMJoe Martin says:
A great idea, And congrats on your first 'ible. I hope to see more :)
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:mysticalvibes
