xbox 360 paint job!!!
This will show you how to disassemble paint then reassemble the xbox 360 controller.
This is what you will need:
-a controller
-t8 screw driver
-tiny philips screw driver
-primer
-spray paint(the colors you want)
-finish(water proof)
-sticky paper
Step 1Step 1: dissamble the controller
take out the 7 screws with t8 screw driver
take out buttons
take out the 2 screws in the d-pad
put every thing in safe place
19 comments
Mar 17, 2010. 3:42 PMstephe911 says:
ok well im trying to paint my controller but im at a roadblock the screws have a little dot in the center preventing me from taking it apart PLEASE HELP
Jun 28, 2011. 2:12 PMracoruesday says:
to get the screws you can uae a 2mm flat head screwdriver and if they break use a allen wrench. thats how i did it. im going to post pictures of mine when its done.
Apr 1, 2011. 10:43 AMSabreT00thPanda says:
You will need a T8 screwdriver which you can get at any hardware store and a flat head screwdriver. You have to use the flathead to break the pin in the center. After all the pins are broken you can open it with a T8 screw driver. Or, you can order a Security Torx T8 from Amazon or Ebay.
Mar 31, 2010. 5:00 PMSteeps5 says:
You need a Security Torx T8. Right here is one that's exactly what you need. http://secure.llamma.com/catalog/product_info.php/cPath/25/products_id/611
Aug 1, 2010. 12:00 PMValeil says:
Or just use a very small(jeweler's/watchmaker's) screwdriver.
Oct 6, 2010. 2:15 PMWasagi says:
Nice! What kind of paint do you use for painting the controllers?
Apr 16, 2010. 10:39 AMundeadboy92 says:
can i just use a flathead and then take the top and bottom off and everything will still be there???   This way it would be easier or will i have to take other stuff off.   Will stuff just like fall out or what??? i would like to get started on this project next week..??
Feb 10, 2010. 4:13 AMMrBlanket says:
 I used red paint with crystal clear enamel and the paint came off and onto my hands when i sweated!! Why is this?
Jan 9, 2010. 7:24 AMmonkeyman580 says:
were did u get the the t8 driver
Jul 26, 2009. 8:03 PMcode9ster says:
Use paint made for Vinyl it won't wear off the plastic
Aug 11, 2009. 9:50 PMShut Up Now says:
if you use vinyl dye, do you still need a clearcoat? also, will your hands smell like paint from using the controller?
Aug 11, 2009. 10:37 PMcode9ster says:
I don't use clear coat I like the look of original. Thats what you will get with the vinyl dye. I guess you could use clear coat I have never tried it. I have never noticed the a paint smell on my hands yet.
Aug 11, 2009. 11:25 PMShut Up Now says:
So the dye isnt really coating the plastic, but is absorbed into it? interesting.. does that mean that using blue dye on red plastic will end with purple or still blue.
Aug 12, 2009. 12:46 PMcode9ster says:
I have never had a red controller only white and black white i paint black
Aug 11, 2009. 10:34 PMcode9ster says:
any paint that says vinyl dye will work make sure it doesn't say vinyl coating if it does it will wear off with hands they always put it in small print.
Jun 4, 2009. 6:03 PMrianocerous says:
What kind of finish did you use, and how are the results holding up to hand wear? I painted mine with Krylon for plastics (which is supposed to bond and not wear off) but it's peeling off bad where my hands touch it on the bottom. It's possible it could be because of surface prep (I cleaned it, but not with acetone or anything) but I'm thinking of trying again. What finish did you use as the topcoat, and how does it feel? does it wear well / get sticky etc?
Jul 22, 2009. 4:01 PMmnhbsfg says:
try sanding and whiping down controller before painting so paint will stick better
Jul 18, 2009. 4:25 PMLetsExplodeSomething says:
did u prime it though?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:browning625
