Step 6Step 06. Attaching the puff
First, using a crochet needle, locate the place where you want to attach the puff. Then, poke from inside to outside, and grab one of the ends of yarn from the puff, and pull through to the inside. Poke through the mitten nearby (but not in the same place) from inside to outside, and grab the other end of the puff, and pull through to the inside. Now you should have both ends of the yarn on the inside of the mitten, but not through the same hole. Knot the yarn on the inside (double or triple), and snip the ends. If you are doing this for a hat, or for something else where you don't want the yarn ends sticking out, you can weave the ends into the knit material. Otherwise, you are done! Now you have a mitten with a puff...
Add Comment
