3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
yet another gps handlebar mount
I'd been looking on Amazon for a handlebar mount for a long time and every time I order it, it goes out of stock. Then I saw this article (http://www.instructables.com/id/EAKFO4VEB6EP306G7G/) and was inspired. I decided to use a different approach though, because I don't want to modify my gps unit in any way.
This is an almost entirely made from scratch solution that didn't cost me anything to make. Of course it helps if you already have some tools. :)
Step 1Parts list
parts list
some sturdy scrap metal. Mine is a piece of brass about 1mm thick, though you could use probably any kind of sheet metal.
a cheap handlebar mounted reflector or similar thing. Mine came with my bike as a freebie to mark the place where your headlight should go.
two machine screws with matching hex nuts or the like.
drill
clamp
a means for cutting metal, I used a jeweler's hand saw
file
pliers or metal bending tool
spray paint
11 comments
Jul 26, 2011. 9:45 AMjpalmer9 says:
your front forks are the wrong way round
Apr 5, 2010. 11:05 AMMnweni says:
I have had a crack at this very useful instructable, but dispensed with the clamp and used cable ties to secure the mount to the the handle bars. I also used a piece of motorcycle tyre to prevent the gps from falling out.
Jan 9, 2010. 12:22 PMTinworm says:
it is called a profile gauge
Dec 19, 2008. 12:25 PMManatee says:
This is a good winter project before Geocaching season in the spring. I really struggled to keep the GPSr stable where I could read it on trails. Thanks
Jul 26, 2009. 11:11 AMqwertyboy says:
it's a depth gauge
Jun 26, 2008. 6:53 AMBluemini says:
THIS IS PROBABLY ONE OF THE BEST AND USEFUL (and EASIEST) THINGS I"VE SEEN ON INSTRUCTABLES!!!!! And, I have the perfect use. I'm sure you know what Geocaching is (since you have a GPSr) And I just bought a bike rack, so now, I have the ultimate mounting systems I did have one question. Is it easy to put in and take out the GPSr?
May 28, 2008. 12:05 PMadallojacono says:
Any thoughts on using a Nuvi 680 on a HD Softail?
Mar 15, 2008. 8:21 AMn0ukf says:
What keeps the GPS from sliding out the sides?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
92
Author:RaisedByRobots
clueless enthusiast
